Default updated tool list
Old 02-06-2010, 04:31 PM   #1
BajaEdition is online now
Modded Resident 'Old' Jeep Shaman
Vehicle(s): 67 cj5, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc front 11 inch drums rear,2 inch lift on 31s, custom seat, armored up 70 cj6 on stretched tj frame with Nth degree lift and all the goodies,33s 08 JK Rubicon with lift and armor
Images: 47
Rep Power: 4 BajaEdition is on a distinguished road
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar
stock out of your hands so that it smacks you in the chest and flings
your beer across the room, denting the freshly-painted project which
you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to
say, "Oh, poopie!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up
jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle ...
It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal
your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing
else is available, they can also be used to transfer intense welding heat to
the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop
on fire. Also handy for igniting the grease inside the wheel hub out of which
you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles
for testing wall integrity.
HYDRAULIC FLOOR JACK :
Used for lowering an automobile to the ground after you have installed your
new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash can after
you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to
disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style
paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as
the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed
to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent to the object we
are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to
your front door; works particularly well on contents such as seats, vinyl records,
liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while in use.
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling, "Son of
a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
THESE REALLY WORK!! I checked this out on Snopes and it's for real!
1. Avoid cutting yourself when slicing vegetables by getting someone else to hold
the vegetables while you chop.
2. Avoid arguments with the females about lifting the toilet seat by using the sink.
3. For high blood pressure sufferers ~ simply cut yourself and bleed for a few
minutes, thus reducing the pressure on your veins. Remember to use a timer.
4.A mouse trap placed on top of your alarm clock will prevent you from rolling
over and going back to sleep after you hit the snooze button.
5. If you have a bad cough, take a large dose of laxatives. Then you'll be afraid to cough.
6. You only need two tools in life - WD-40 and duct tape. If it doesn't move and
should, use the WD-40. If it shouldn't move and does, use the duct tape.
7. If you can't fix it with a hammer, you've got an electrical problem.
DAILY THOUGHT:
Some people are like slinkies - not really good for anything but they bring a smile
to your face when pushed down the stairs.
I learn from my mistakes. I will learn a lot today.
Hope you are having a GREAT day
Jim
Moderator in charge of putting foot in mouth
My Mouth Hurts
www.justgoodtrails.com
Default Re: updated tool list
Old 03-14-2010, 06:10 PM   #2
LASTCJ786 is offline
LASTCJ786
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 30 LS Dana 44 locker 3:73's,4"lift ,1" body.York OBA, Warn 8274,Fullcage.
Rep Power: 1 LASTCJ786 is on a distinguished road
You got to have a Die grinder with carbide tip and one with a cut off wheel.
Old 03-16-2010, 03:26 AM   #3
IOPort51 is online now
Vehicle(s): 1977 cj-5 4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30, skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road. 1981 J-10 4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
Images: 39
Rep Power: 3 IOPort51 is on a distinguished road
The tubing cutter was created to remove the beautiful flair you just put on a dangerously short section of copper tube so you can put the flair nut you forgot on before you re-flair it.
Old 03-16-2010, 05:53 PM   #4
Images: 47
now that is a good one
My Mouth Hurts
list, tool, updated
The Man Cave Tool Box CJ Sand, Dirt and Mud 12 03-06-2010 04:58 PM
Favorite tool? CJ Shops, Equipment and Tools 53 10-31-2009 07:26 AM
Tool Tip of the day BrockGrimes Shops, Equipment and Tools 3 09-16-2009 08:19 PM
Need to have tool 2lostspace Shops, Equipment and Tools 8 08-10-2009 01:30 PM
Gallery Updated CJ Site Related News, Announcements and Polls 0 05-31-2009 04:56 PM
