Default Trailer project
Old 11-08-2009, 11:15 AM   #1
Thorwon is offline
Thorwon
Vehicle(s): 1974 CJ5 304 3sp, 1966 CJ5 134"F" 3sp with Warn OD
Thorwon's Avatar
Rep Power: 2 Thorwon is on a distinguished road
I found a CJ7 tub on CL for $100. It came with front fenders, hood, windshield frame and grill. It is rusty as hell but I've been wanting to build a CJ trailer anyway so I bought it. Someone welded new floors in but they did not cut the old rusted floors out first.
I have a old bass boat trailer I'm going to cut up to use the frame and axle to build my jeep trailer with.
I was going to use my hand grinder to cut the tub with, but I discovered it just eat the cut-off wheels up. So out comes the sawsall, it went through it like butter.
I'v got to do some rust removal and weld up a frame under the tub to mount to the trailer frame. (most of the tub mounts are rusted out)
I'll post more as I get the chance to work on it.
No mater how good lookin she is somewhere out there is a guy tired of her S*@#
Default Re: Trailer project
Old 11-08-2009, 11:57 AM   #2
mylittlecj5 is offline
mylittlecj5
Vehicle(s): '74 CJ-5, 360 AMC Engine. Accel HEI module/ TFI Ignition. Holley Truck Avenger carb. T-150 3 speed trans. Model 30 Front diff. Drum Brakes. Dana 44 rear diff (Lincoln Locked). 4" SkyJacker SoftRide lift. 2" lift shackles. Front shackle reversal. TJ fender conversion in rear. 35x12.50x15 TSL Super Swamper tires. Optima Red-Top Battery. Full Roll Cage w/ 4 point harnesses. Custom Seating. 8000 Lb. winch on custom front bumper.
mylittlecj5's Avatar
Images: 9
Rep Power: 3 mylittlecj5 is on a distinguished road
Looks like a good start! I wish I would have had the forethought to cut my CJ7 up in the right place to make a trailer out of it. But I cut it too far back to keep the box intact.
Old 11-09-2009, 10:13 PM   #3
Thorwon is offline
Thorwon
Thorwon's Avatar
I had a chance to weld the trailer frame last night. I set it up with SOA and didn't like it, was just to high, so for now it's now SUA. I want to find a set of CJ springs. Of course I can always change it if I put a bigger lift on my CJ.
I had to take 30" out of the axle.
More to come.
Old 11-09-2009, 10:38 PM   #4
Modded Resident 'Old' Jeep Shaman
Vehicle(s): 67 cj5, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc front 11 inch drums rear,2 inch lift on 31s, custom seat, armored up 70 cj6 on stretched tj frame with Nth degree lift and all the goodies,33s 08 JK Rubicon with lift and armor
Images: 47
Rep Power: 2 BajaEdition is on a distinguished road
ok now, this is just getting to good.
I am hooked on thsi thread already.
Only on Jeep-CJ
Your one stop internet place for the greatest in real life CJ lifestyle.
Moderator in charge of putting foot in mouth
My Mouth Hurts
www.justgoodtrails.com
Old 11-09-2009, 11:46 PM   #5
LongHorn is offline
LongHorn
Vehicle(s): 83'CJ-8 Scrambler Slightly Modified;), 67'Jeep M-725, 88'YJeep Wrangler Slightly Modified;)
LongHorn's Avatar
Images: 39
Rep Power: 4 LongHorn is on a distinguished road
Old 11-10-2009, 12:12 AM   #6
LongHorn is offline
LongHorn
LongHorn's Avatar
Images: 39
Old 11-10-2009, 12:18 AM   #7
Vehicle(s): 1977 cj-5 4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30, skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road. 1981 J-10 4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
Images: 39
Rep Power: 3 IOPort51 is on a distinguished road
what would make a trailer is a J-10 bed, I don't think I will donate mine for the project but just saying.
these are all good jobs.
Old 11-10-2009, 12:31 AM   #8
LongHorn is offline
LongHorn
LongHorn's Avatar
Images: 39
Old 11-10-2009, 09:20 AM   #9
2BAD4U is offline
2BAD4U
Vehicle(s): 68 Jeepster Commando, 05 Sportsman 700, JD X320
2BAD4U's Avatar
Images: 13
Rep Power: 1 2BAD4U is on a distinguished road
Nice project Thorwon! That's going to be a cool trailer fer shizzle! A roll bar would be a nice touch, and a tie down point as well.
BTW I sure do miss that perdy red clay and all of those pine trees! Makin' me home sick!
JEEP *assembly IS required!
Old 11-24-2009, 08:10 PM   #10
Thorwon is offline
Thorwon
Thorwon's Avatar
I have been able to work on the trailer off and on during the last week. I just haven't had my camera (my mother inlaw had it).
I got the mounts welded on the tub and frame, then bolted the tub on. I used tub mounts for a cj5 from Energy Suspension (poly).
I welded a frame for the front out of small channel that I picked up at a local auction. I'm covering it with some 14 ga. metal I had. It'll be four pieces across the front so I hope I can weld it good enough to make it look right. If not I'll smooth it with bondo.
The floor I pieced together with small pieces of 14 ga. when I get it all welded I'm going to sand blast it all, prime the tub and coat the inside with fiberglass.
project, trailer
Project Tub Swap certifiablejeep Misc CJ Discussion 111 09-23-2009 07:40 AM
New project in the yard... coldwater Sand, Dirt and Mud 17 06-05-2009 06:53 PM
One more project 2lostspace Non Jeep Vehicles 6 05-03-2009 01:48 AM
Picked up a new project mylittlecj5 Non Jeep Vehicles 7 04-05-2009 11:43 AM
project bwbfarms Drivetrain 5 02-18-2009 04:32 AM
