Custom Axe & Shovel rackThis is a discussion on Custom Axe & Shovel rack within the Any and ALL Aftermarket Parts and Additions forums, part of the Non Jeep Vehicles and ALL Parts and Accessories category; This is the start to finish rack system.
Sorry if it is hard to see but if some one wants ...
03-21-2009, 04:44 PM
Vehicle(s): 2002 Jeep Sahara, dana 30 F. dana 35 R. stock tranny, 4.0 automatic, stock transfer case.
Re: Custom Axe & Shovel rack
03-22-2009, 07:55 AM
Vehicle(s): '79 CJ5, 04 WJ Limited
Looks good. Looks like you used 1" thin wall square tubing, mounted it across the roll bar legs with U-bolts, and used some sort of rubber clamping thing to hold the shovel and axe.
Where did you get the rubber clamping things?
Have you seen signs of too much stress on the tubing or mounts caused by the weight of the axe and shovel twisting around as they get shaken while driving?
03-23-2009, 01:10 PM
i mounted my rack on the passenger side wheel weel, but i have a cj7 so it's slightly longer. i used clamps meant for use on an atv. they have securing straps and seem to work well.
03-23-2009, 08:16 PM
You are right with the 1" square stock (Home Depot, 48" long), 2 1/2" U-bolts 1/2" thread size, I tried the rubber spray paint, its the stuff they sell in the can you can dunk your plier handles in, it's ok I think it will collect dirt & dust fast, NO stress cracks and I used a mig welder and it is very solid (we went sunday for about 5 hours wheeling) The clamps I got from Cabela's, they are "Quick Grips" $8.00 a pair and they are made specificly for that application, if you don't have a Cabela's store they have a web site.
I did find out this weekend that with the top on it was a pain in the a s s to get stuff from the back, had to climb over the thing. I am in the process of changing it to hinge open in the same direction as the tail gate. I picked up some parts tonight and will put a finished pic up soon.
03-23-2009, 08:19 PM
You most likely have the same one's I used. I had to make it out of the way due to it's my wifes Jeep and she wants it keept looking normal  , so we compermised
Got a Picture?
03-25-2009, 09:23 PM
For thoes following this project, I have hinged the unit and will post the finished product after I finish the paint and latch system.
03-26-2009, 09:50 PM
#7
03-27-2009, 07:34 AM
#8
72 CJ5 Owner
That sure looks good and clean. Is there any rattling?
03-27-2009, 07:56 PM
#9
No, so far so good. I hate rattling, it drives me nuts. I did add a nylon washer on the hinge side and when I drilled the hole for the pin I made sure it was tight enough.
I did use the new "Rubber" spray paint that home depot sells, it's like the stuff you would dip your handle of your tools in to rubber coat them, only it comes in a spray version, maybe that helped.
Dave
05-15-2009, 12:36 AM
#10
Nice! I had planned on mounting my HiLift jack in the same place, but it's just not working out too well. Sonya the Wonder Dog hits her head on it when she jumps into the Jeep.
