Default Timing and Harmonic Balancer
Old 04-01-2010, 10:09 AM   #1
Jeepmerunning is offline
Jeepmerunning
Vehicle(s): 1985 CJ7. Inline 6. Mostly stock with a 3 inch body lift. 33 inch MTs. Dana 300 tcase. T-176 tranny.
Jeepmerunning's Avatar
Rep Power: 0 Jeepmerunning is on a distinguished road
My 1985 CJ sputters when turning off the key. I can only reach 50mph when going downhill. I found the distributor bolt very loose, so I think I've got a timing issue. I borrowed a timing light, but I'm not sure where to point the strobe. Is it the harmonic balancer? Is that in front of the block? Any images? 1985 CJ I6.
Default Re: Timing and Harmonic Balancer
Old 04-01-2010, 11:11 AM   #2
Images: 219
There is a mark (line) on the balancer and a graduated plate on the front of the engine. You want to rotate the distributor until the mark on the balancer lines up with the correct ignition timeing for your I6. Probably around 5 degrees before top dead center (with the vacuum line disconnected from your distributor). Could be different if there are any modifications - I'm not very knowledgeable on the I6 specs.
Please fill out your profile as direct when you created your account. It helps us know what you CJ is equiped with.
Old 04-01-2010, 11:48 AM   #3
TDHofstetter is offline
TDHofstetter
Vehicle(s): '73 CJ5 232/T14/D20/D30/D44, '74 CJ5 Renegade 304/T15/D20/D30/D44, '85 CJ7 258/T5/D300/D30/AMC20
TDHofstetter's Avatar
Rep Power: 8 TDHofstetter is on a distinguished road
This is exactly what you're shooting at with your timing light:
-- Tim --
Old 04-01-2010, 12:09 PM   #4
Resident 'Old' Jeep Shaman
Images: 141
Well TD to the rescue
I mean where else but at Jeep-CJ.com do you finf guys that go that much out of the way to help you out.
This has to be the best CJ site on the web
Old 04-01-2010, 12:10 PM   #5
Jeepmerunning
Thanks for the replies. I see the image showing the "notches." Should they be numbered? I was under the impression the notches count up from zero in both directions. The image is very useful. Thanks again.
Old 04-01-2010, 01:00 PM   #6
TDHofstetter
The second little tick mark from the tube thingie (which is actually a socket for a special timing tool none of us will ever see) is 0. To the left is BTDC (before top-dead-center), which is where you want to go. Each tick mark is two degrees; in that bottom photo you can barely see the bottom end of the 20BTDC mark. YOU will want about 9 degrees BTDC, so set it between the 4th & 5th tick marks. That's with the vacuum hose pulled off the distributor & plugged and the engine idling. If you get detonation ("rattle") on acceleration, back it up to 7 degrees.
-- Tim --
Old 04-01-2010, 01:03 PM   #7
Each notch is 2 degrees and the notch farthest to the drivers side is 0 or Top Dead Center (TDC).
My book says you should be at 9 degrees before TDC
Old 04-01-2010, 02:38 PM   #8
Rep Power: 16 Old Dog is on a distinguished road
Originally Posted by TDHofstetter View Post
The second little tick mark from the little tube thingy is 0.
Ok guys which is it.?
And why would AMC make it so confusing?
Old 04-01-2010, 03:10 PM   #9
TDHofstetter
From the FSM:
Old 04-01-2010, 03:59 PM   #10
AMC wasn't confused I was.
I should have said"the one that says 0"
balancer , harmonic , timing
304-360 harmonic balancers fuzzy Drivetrain 2 09-14-2012 11:06 AM
Buick 225 Harmonic Balancer Search....PLEASE HELP DanTetrick Drivetrain 4 06-30-2012 02:48 AM
Are 304-360 harmonic balancers the same? OEM1984CJ7 Drivetrain 5 06-02-2012 03:02 PM
Harmonic Balancer torque, carb linage suburban99 Drivetrain 4 03-17-2011 11:49 AM
Crank damper or harmonic balancer ? CJim7 Drivetrain 4 01-14-2011 10:21 PM
