Default taurus electric fan question.
Old 01-18-2010, 12:58 AM   #1
I think I have a problem with the electric fan install, it won't fit!
I have slightly more than 3" on the back side of the radiator and slightly less than 4" on the front side . The fan will require at least 4.25 inches.
Has anyone done this with a CJ5 and/or a l6?
Default Re: taurus electric fan question.
Old 01-18-2010, 12:45 PM   #2
Most of the write-ups I've seen were with V8's.
This is such a common swap google should come up with a million hits.
Old 01-18-2010, 06:09 PM   #3
BrockGrimes is offline
BrockGrimes
Jeep-CJ.com Archive Master
Vehicle(s): Jeep?
BrockGrimes's Avatar
Images: 99
Rep Power: 12 BrockGrimes is on a distinguished road
I have.
See this thread:
http://www.jeep-cj.com/forums/f49/us...-id-share-665/
Old 01-18-2010, 11:08 PM   #4
Originally Posted by BrockGrimes View Post
The first place I looked. All the pictures seem to have serpentine belts and a lot more room between the radiator and the water pump pulley.
I am going to find a twin fan out of a ford next weekend and see if I can make that work.
Brock, do you use the contour fan?? if so do you run both at once or cycle them independently?
Old 01-23-2010, 10:03 AM   #5
BrockGrimes
Vehicle(s): Jeep?
Images: 99
I ran a ford taurus fan in my cj5 with the 258.
Old 01-23-2010, 10:05 AM   #6
did you have to offset it to one side of the water pump pulley? or was there room between the pulley and the radiator?
Old 01-24-2010, 08:42 PM   #7
BrockGrimes
Vehicle(s): Jeep?
Images: 99
If i remember correctly there was enough room for it to be safe enough for offroading but not much more. A ford contour will be a better fit most likely not to mention a better over all fan. Plus it doesn't have the amp draw issues the taurus has.
Also it fits the radiator better as far as coverage.
electric , fan , question. , taurus
Another electric fan question. TACAMO Misc CJ Discussion 10 08-21-2012 04:01 PM
Electric fan help poser Drivetrain 2 09-11-2011 10:32 PM
Question about electric fan on 258 in-line 6 cyl. dvandebrake Drivetrain 5 09-24-2010 03:51 AM
Electric question dave pam Drivetrain 7 03-19-2009 03:40 PM
Electric Water Pump vs Electric Drive kit jeep cj7 304 Drivetrain 8 01-30-2009 10:03 PM
