Default Please Need Lil' Help - Jeep CJ Dimensions ??
Old 01-11-2011, 09:23 PM   #1
Smokey2yunick is offline
Smokey2yunick
Rep Power: 0 Smokey2yunick is on a distinguished road
Hello -
I've been all over the internet looking for some critical dimension for early/or even later CJ5 dimesions. Can I get some help with the below measurements for a project i'm starting. Looking for stock info if available.
A - Top of front fender from ground
B - Ground to top of frame
C - Top of fender , to top of hood
D - Top of wheel to ground (highly critical for rest)
E - Front lip of fender to end of fender curve
F - Length of hood
G - Ground to bottom of frame
H - Ground to top of window
I - Ground to top of frame/bottom of body
J - Width of tub from rear fender seam to start of rear arch
K - Width of end of fender to inside of door
L - Inside door to bottom of door arch
M - Distance betwen tire and bottom of front fender clearance
N - Distance betwen tire and bottom of rear fender clearance
O - Width of wheel arch from bottom
P - Height of Rear tire (critical for all measurements)
Q - Width of rear wheel arch to rear of tub
R - Height of rear tub to ground
S - Bottom of tub to top of tub
Thanks in advance - Patrick
Default Re: Please Need Lil' Help - Jeep CJ Dimensions ??
Old 01-11-2011, 09:43 PM   #2
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 12 mylittlecj5 is on a distinguished road
you may have to decide if you want early, intermediate, or late model CJ.
They all have slightly different specs.
Not to mention you didn't specify what if any lift you want and tire size (there are variations on the stock stuff also), model of CJ you want (CJ2,3,5,6,7,8), ect.
This sounds like a pretty detailed project, how about giving us some details to work with you on?
I guess this is as close to stock specs as I have, but its all just frame references. I don't think I've ever seen such detailed specs on the body stuff.
Default Re: Lil' Help - Jeep CJ Dimensions
Old 01-12-2011, 12:25 AM   #3
Smokey2yunick
I'll take any body info from any year would help.
Ideally I would like an: intermediate CJ5, stock height with 31" tires (pretty rare I know hahaha)
Sorry I can't give any hints until it's done, but I will post a write up when finished. I don't tell until projects are done because sometimes forum e-thugs like to crush new ideas. < not on this forum yet, just some past forum expierence.
Old 01-12-2011, 02:44 AM   #4
BrockGrimes is offline
BrockGrimes
Jeep-CJ.com Archive Master
Vehicle(s): Jeep?
BrockGrimes's Avatar
Images: 99
Rep Power: 11 BrockGrimes is on a distinguished road
I know the jeep bible has some measurements, I'd start there first.
Hit up a fiberglass/metal body mfg, tell em you need the measurements for a frame and exo cage your building.
Check here: http://www.the-blueprints.com/blueprints/cars/jeep/
Also here: search for D&L Bensinger check their site or email them.
Old 01-12-2011, 11:15 AM   #5
bmflyfish is offline
bmflyfish
Vehicle(s): Brown 1985 4 speed CJ-7 with the 258, Dana 300, AMC 20 and Dana 30 still with the stock axles.
bmflyfish's Avatar
Rep Power: 0 bmflyfish is on a distinguished road
Here is a frame diagram for a 75 CJ5 and 6.
The Following User Says Thank You to bmflyfish For This Useful Post:
CJ (01-12-2011)
Old 01-12-2011, 01:34 PM   #6
ken98k is offline
ken98k
Vehicle(s): {1980 cj-5, 258, t-176, d300 amc20 rear, D30}{1974 cj-5, 304, T-15, D20, D30 front, D44 rear}{1973 cj-5, 304, t-98,D20, amc20, D30} {1990 yj 2.5L i-4 AX-5 NP231 Dana 30 front Dana 35c rear} 1996 XJ Cherokee 4.0 HO {2000 silverado} {1979 Cadillac Sedan DeVille}
ken98k's Avatar
Images: 5
Rep Power: 8 ken98k is on a distinguished road
The differences in the frame of my 73 and 80 cj's are pretty significant.
Old 01-12-2011, 09:55 PM   #7
Smokey2yunick
Just talked to Quadratec, they had no body details either. Emailed some fiberglass companies that make the tubs, so we'll see. Didn't realize this would be that hard
Old 01-13-2011, 09:47 AM   #8
BrockGrimes
Vehicle(s): Jeep?
Images: 99
It's not to hard, I've gotten that info in the past from one of the sources listed above, just can't remember which one, lol. I'm thinking one of the jeep bibles.
Old 01-13-2011, 09:18 PM   #9
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 10 73CJ is on a distinguished road
My 73 CJ5 came with 27.5" Goodyear H78x15.
Not sure what you're going to do with the dimensions, but if you're after tub info the tubs were all the same except the body mounts. Now the year comes into play. 76s frames are wider in the rear. Pre-72 had a shorter hood and front fenders by 3-4 inches.
Give us a hint and not quite so many dimensions right off the bat.
Old 01-18-2011, 08:47 PM   #10
Smokey2yunick
Great help, getting there. Checked out the "jeep bible 2004 ed." wasn't too useful for measurments, but I did find this below pic online. I'll add in the dimensions to it as get them.
dimensions , jeep , lil
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Lil' Bama Project BamaCJ CJ Build Forum 14 02-27-2013 01:43 AM
m100 trailer dimensions johnnyreb Outdoor Related 3 01-21-2013 10:29 AM
cj7 Dash dimensions rcoles871 Misc CJ Discussion 1 07-04-2012 11:54 AM
anybody got the stock dimensions? kickitandholdit Suspension and Steering 2 06-26-2011 12:04 PM
Need Some Dimensions musciab Drivetrain 1 05-27-2011 07:25 PM
