Default Ignition Lock Cylinder Replacement
Old 04-16-2010, 01:21 PM   #1
sbrodacz is offline
sbrodacz
Vehicle(s): -78 CJ7 -Chevy 350 -TH400
Rep Power: 9 sbrodacz is on a distinguished road
Send a message via AIM to sbrodacz
I believe the part is called an ignition lock cylinder. Has anyone replaced one on a CJ. My CJ doesn't need a key to start and I'd really like to be able to fix that. I can get the part at Orileys for $30 but I wasn't sure what was involved in the install.
Default Re: Ignition Lock Cylinder Replacement
Old 04-16-2010, 04:01 PM   #2
sbrodacz is offline
sbrodacz
Sorry, I had thought i posted this in Electrical.
Old 04-16-2010, 04:20 PM   #3
Buuushman is offline
Buuushman
Vehicle(s): 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Buuushman's Avatar
Images: 7
Rep Power: 9 Buuushman is on a distinguished road
swapping the cylinder is pretty easy- you will need a steering wheel puller and a lock ring depressor tool, the rest of the tools are basic stuff you should have laying around- a chiltons or factory service manual will really help you here- step by step instructions.
77' CJ-5, 360, Cam, Intake, Headers, H.E.I., Holley carb, Solid axles, an' plenty custom welded goodies- only peepin' up when it's necessary- or I'm
Old 04-16-2010, 04:22 PM   #4
sbrodacz is offline
sbrodacz
I have been wanting to purchase a service manual.
Old 04-16-2010, 04:28 PM   #5
Buuushman
Buuushman's Avatar
Images: 7
Someone on here should have a link to where you can buy one- all I have is the chiltons- cant beat the price for @ $20.00
Old 04-16-2010, 04:36 PM   #6
CJ is online now
Images: 219
Tilt or No Tilt wheel?
Old 04-16-2010, 04:40 PM   #7
sbrodacz is offline
sbrodacz
I will probably grab one of those as well.
I believe no tilt. Thanks for the picture.
Old 04-16-2010, 04:46 PM   #8
CJ is online now
Images: 219
Great article on how to pull the top half off of the wheel to get to the lock. -->> How To Rebuild Your 80's Chevy Steering Column - Texas4x4.org
Old 04-16-2010, 04:52 PM   #9
sbrodacz is offline
sbrodacz
Awesome! Thank you!
Old 10-29-2010, 05:56 PM   #10
sbrodacz is offline
sbrodacz
Originally Posted by Brandon Mitchell View Post
You can have a key cut by the dealer to fix the problem. That would be one option and I think its the best one.
I can start the Jeep with out a Key, you think having a key cut would fix the problem? How can I get a key cut without having a key? Would a jeep dealership have a "mold" for the key? I remember I had a 99 camaro and lost the key and the dealership was able to have a key cut. Would this be the same concept? I have not changed the cylinder yet because the bolts to take the steering wheel off are stripped.
It would be a lot easier if I could go to Jeep with my vin and have a key cut...
78 CJ7
Build in the works
cylinder , ignition , lock , replacement
1977 Ignition Cylinder Removal ProV1 Chassis and Body 6 05-06-2013 08:06 PM
Key trapped in ignition/remove tilt lock lever CB2L Misc CJ Discussion 9 01-30-2012 04:07 PM
lock cylinder 84Cjseven Misc CJ Discussion 4 08-08-2011 11:03 PM
Ignition Lock help Major Mustachio Chassis and Body 2 05-01-2011 06:36 PM
Bad key lock cylinder Sasquach Misc CJ Discussion 2 05-10-2010 04:14 PM
