Jeep-CJ Forums
-   Chassis and Body (https://www.jeep-cj.com/forums/f7/)
-   -   Ignition Lock Cylinder Replacement (https://www.jeep-cj.com/forums/f7/ignition-lock-cylinder-replacement-4616/)
sbrodacz 04-16-2010 01:21 PM
I believe the part is called an ignition lock cylinder. Has anyone replaced one on a CJ. My CJ doesn't need a key to start and I'd really like to be able to fix that. I can get the part at Orileys for $30 but I wasn't sure what was involved in the install.
sbrodacz 04-16-2010 04:01 PM
Re: Ignition Lock Cylinder Replacement
Sorry, I had thought i posted this in Electrical.
Buuushman 04-16-2010 04:20 PM
swapping the cylinder is pretty easy- you will need a steering wheel puller and a lock ring depressor tool, the rest of the tools are basic stuff you should have laying around- a chiltons or factory service manual will really help you here- step by step instructions.
sbrodacz 04-16-2010 04:22 PM
I have been wanting to purchase a service manual.
Buuushman 04-16-2010 04:28 PM
Someone on here should have a link to where you can buy one- all I have is the chiltons- cant beat the price for @ $20.00
CJ 04-16-2010 04:36 PM
Tilt or No Tilt wheel?
http://www.jeep-cj.com/forums/../gal...ocknontilt.jpg
sbrodacz 04-16-2010 04:40 PM
I will probably grab one of those as well.
Originally Posted by CJ (Post 41604)
I believe no tilt. Thanks for the picture.
CJ 04-16-2010 04:46 PM
Great article on how to pull the top half off of the wheel to get to the lock. :) -->> How To Rebuild Your 80's Chevy Steering Column - Texas4x4.org
sbrodacz 04-16-2010 04:52 PM
Awesome! Thank you!
sbrodacz 10-29-2010 05:56 PM
Originally Posted by Brandon Mitchell (Post 58328)
You can have a key cut by the dealer to fix the problem. That would be one option and I think its the best one.
I can start the Jeep with out a Key, you think having a key cut would fix the problem? How can I get a key cut without having a key? Would a jeep dealership have a "mold" for the key? I remember I had a 99 camaro and lost the key and the dealership was able to have a key cut. Would this be the same concept? I have not changed the cylinder yet because the bolts to take the steering wheel off are stripped.
It would be a lot easier if I could go to Jeep with my vin and have a key cut...
