Default how to replace an alternator
Old 05-21-2011, 03:37 AM   #1
wrightmercy is offline
wrightmercy
Spammer
Rep Power: 0 wrightmercy is on a distinguished road
here's how to replace an alternator.
First Open the hood and locate your vehicle's alternator.
Next check the battery by the use of digital multi-meter if the result is dead (if the voltage is below 9 v it is considered as dead).
Next verify your alternator if it bad. to very this make sure your battery is fully charged.
if good battery (voltage of good condition battery is at 12-13v) is installed, onnect your digital multi-meter across the battery terminals make sure the engine is turn-off.
Start the engine and read the digital multi-meter's output. The voltage should rise near 13.5-14.5 volts.
Using a wrench, disconnect the battery's negative cable.
Disconnect the power and ground wires on the back of the alternator paying close attention to where each wire connects. Disconnect the wiring harness connector.
for more of the details just visit the link how to replace an alternator. (i got this steps by step procedure on that site.)
Default Re: how to replace an alternator
Old 05-21-2011, 07:49 AM   #2
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 12 mylittlecj5 is on a distinguished road
this write up should go into the archives...deep, deep into the archives...never to see the light of a computer screen again...
Old 05-21-2011, 07:59 AM   #3
Images: 219
Did you see their title?
Old 05-21-2011, 08:29 AM   #4
mylittlecj5
Images: 9
LOL yea..I didn't know if that was you or them...
alternator , replace
Replace captive nut Davezilla Chassis and Body 3 10-28-2012 04:29 PM
What Transmission will replace BW-T4 RedDog Drivetrain 3 04-19-2012 03:15 PM
Fix or replace? drivert51 Misc CJ Discussion 8 03-05-2012 09:32 PM
Changing from the stock Alternator to 150Amp Alternator scottPlymesser Misc CJ Discussion 1 04-12-2011 09:53 PM
the best alternator swap for your CJ with a GM alternator rushpowersystems Chassis and Body 7 02-08-2010 08:24 PM
