Default Hood caulk?
Old 04-07-2012, 07:55 AM   #1
danc9 is offline
danc9
Vehicle(s): 1975 CJ 6, 258 I6, T-14, Dana 20, Dana 30, Dana 44
danc9's Avatar
Rep Power: 7 danc9 is on a distinguished road
I need to know what was used to seal the forward and rear cross member supports on the hood. It looks like some kind of caulk, sealant?????
Thanks, DAN
Default Re: Hood caulk?
Old 04-07-2012, 08:27 AM   #2
I must ask this: why do you need to know? I would guess you want to take this apart? I would say don't. but Eastwood will have some kind of panel adhesive to replace it with. I understand they used that to avoid the distortion in the hood that would be caused by spot welds.
Please find/make a hood brace to hold that hood open. the thought of the crease you are getting in the hood and the strain on the hinges is making chills run up and down my spine.
Old 04-07-2012, 03:08 PM   #3
danc9 is offline
danc9
danc9's Avatar
Thanks IO, that is from an image I found on line. NO, I don't put the hood up like that, old enough now to respect things that can "ring my bell!" I'm not taking it apart, all the material there is broke loose and I want to replace it.
DAN
Old 04-07-2012, 04:56 PM   #4
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 11 Sasquach is on a distinguished road
Eastwood Seam Sealer Cartridge Black
Just an example
Old 04-07-2012, 08:02 PM   #5
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 11 73CJ is on a distinguished road
Most auto body supplier have body panel adhesive. Mine came loose and rattled. Glued it up and solid now.
Old 04-08-2012, 09:34 PM   #6
jamie is offline
jamie
Vehicle(s): 76 cj 5 360, 999 tranny and dana 300 transfer case, dana 44 rear and dana 30 front diff
jamie's Avatar
Rep Power: 8 jamie is on a distinguished road
sooo, propping my hood open with my windshield frame is a bad idea?
evil will always triumph over good because good is dumb.
dark helmet
Old 04-08-2012, 09:51 PM   #7
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
I believe IO was refering to the picture of the hood open and laying against the tub with no winsheild frame mounted.
Default
Old 04-08-2012, 10:17 PM   #8
wondernad is offline
wondernad
Vehicle(s): 79 CJ7 304, 98 XJ 4.0l, 90 YJ 2.5, and 93 240sx sr20det
wondernad's Avatar
Rep Power: 7 wondernad is on a distinguished road
I have put mine up against the windshield since I bought it in 2000. Got a nice mark running across the hood from where it contacts windshield. Not a creese but more of a extreme scratch. Currently rebuilding my Jeep, gonna work in a hood prop.
Sent from my SPH-D710 using Tapatalk
Old 04-09-2012, 12:30 AM   #9
every thing is all fun and games until a tail wind drops the hood on your body parts. As I get older and less bullet proof I think about these things differently.That is my biggest concern. yea I have a crease too, you know just every now and then you don't want to jack with the rod.
mostly it was the shot of the hood bent over the cowl like that that made me cringe.
Old 04-09-2012, 06:41 AM   #10
Jimbos76cj is offline
Jimbos76cj
Vehicle(s): 83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!! Ask me about my head light upgrade harness!!!
Rep Power: 8 Jimbos76cj is on a distinguished road
Napa sell automotive seam sealer.. comes in standard caulking tube.
A guy on a local forum has built a hydraulic prop system for his CJ hood. next time i see him Ill try to get some pics.. Im really interested in doing it to mine.
caulk , hood
Hood Pole? OLD 9 Chassis and Body 9 04-12-2012 08:22 PM
hood cwacj7 Chassis and Body 0 01-07-2012 01:45 PM
hood cwacj7 Chassis and Body 4 01-07-2012 01:37 PM
Plumbers Putty vs Body Caulk steve1973 Chassis and Body 8 12-30-2010 06:10 PM
hood? jeepman Chassis and Body 6 09-12-2010 03:53 PM
