Default Hartop door seals
Old 01-10-2011, 08:51 PM   #1
Gary is offline
Gary
Vehicle(s): 1980 CJ5, pretty much rebuilding it stock, 4 speed, 4 cylinder, front disk brakes, power brakes, power steering.
Rep Power: 0 Gary is on a distinguished road
I am rebuilding a 1980 CJ5, it came with a (aftermarket) Acme hardtop, can anybody help me with the seal design that came on the doors?
Default Re: Hartop door seals
Old 01-10-2011, 09:57 PM   #2
Acme Hardtops
Yes those are the hard tops that have the sliding front windows.
If I am not mistaken they have foam weather seal like most automotive doors. You can get that stuff at J.C. Whitney. They have several types and shapes.
If that doesn't help please extrapolate on your problem sealing the doors.
Also post some pictures. That should help us help you.
Old 01-10-2011, 10:03 PM   #3
elwood blues is offline
elwood blues
Images: 58
Rep Power: 12 elwood blues is on a distinguished road
I had an ACME top and doors on my CJ7 when I bought it. I had an absolutely horrible time trying to get new door seals to stick. I used 3M weatherstripping adhesive and a lot of the $1.99 clamps that you can get at the home depot. The biggest thing about getting the new weatherstripping to stick is to completely clean off the old adhesive. It's a royal pain in the you know where to get all of that stuff off of the fiberglass of those doors. Same goes for replacing the weatherstripping on the top. Here's a good link with a great write-up by a guy who completely refurbed a CJ5 ACME top.
1979 Jeep CJ-5 Buildup: Acme Hardtop Restoration
The Following User Says Thank You to elwood blues For This Useful Post:
Gary (01-10-2011)
Old 01-10-2011, 10:06 PM   #4
Gary is offline
Gary
Thank you for your response, I have looked at the JC Whitney seals but was not sure which one was similar to original or which one would work well. I have no seal left on my doors to use a an example.
Old 01-10-2011, 10:16 PM   #5
Gary is offline
Gary
Thank you, I had read his article, which is great, BUT, he does not say what he used for the seal
Old 01-10-2011, 10:22 PM   #6
elwood blues
Images: 58
I just read the whole thing through, he doesn't say does he? That kind of sucks. Just a suggestion, you could use a set of CJ7 door weatherstrips and cut them to fit. You'd have to cut a universal set so you'd have a seam one way or the other...
FAIRCHILD INDUSTRIES DOOR SEAL WEATHERSTRIPPING FOR CARS,TRUCKS, AND SUV'S - JCWhitney
Old 01-10-2011, 10:27 PM   #7
gert is online now
Rep Power: 12 gert is on a distinguished road
soffseal.com they have universal stuff that might do it for you
acme hardtop , cj5 , door , hartop , seals
I just bought full doors and hartop for $350 need them painted dilloz12 Chassis and Body 3 07-04-2012 03:52 PM
'76 CJ7 full steel door seals, panels, etc. AdamH Chassis and Body 2 11-15-2011 08:20 AM
Window seals Brixy Chassis and Body 2 12-28-2010 11:27 AM
amc 20 axle seals aj0923 Drivetrain 7 06-06-2010 07:44 PM
AMC 20 axle seals lgbent Drivetrain 5 10-30-2009 10:56 AM
