Default Frame difference
Old 05-29-2010, 12:10 PM   #1
nitor is offline
nitor
nitor's Avatar
Rep Power: 10 nitor is on a distinguished road
I'm sure someone has asked this in the past, but what's the difference between a CJ frame and a YJ frame?
Thanks - Jim
1985 CJ7
Default Re: Frame difference
Old 05-29-2010, 03:44 PM   #2
There are lots of differences. The CJ frame has lots of extra holes in it. The reason is they used one frame irregardless of what engine and accessories it has. The YJ had the brackets for the engine mounts welded on. The YJ has a stronger frame. The frame on the YJ makes a bigger arch over the rear axles.
Old 05-29-2010, 04:07 PM   #3
nitor is offline
nitor
nitor's Avatar
Thanks Dave.
Old 05-30-2010, 09:49 PM   #4
LASTCJ786 is offline
LASTCJ786
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
Rep Power: 9 LASTCJ786 is on a distinguished road
The YJ frame is wider and the Grille mount is different and the back rear holes are farther apart.The Spring hangers in the front are wider then the front CJ hangers sames as the rear.
difference , frame
difference in 74 and 76 cj kodiak0000 Chassis and Body 8 07-22-2017 05:28 PM
Difference between '83 and '85 258? loyalpoke Drivetrain 7 03-21-2013 02:59 PM
Model difference fastkricket Chassis and Body 2 02-13-2012 07:01 AM
what is the difference no4low Chassis and Body 4 04-22-2011 10:26 PM
Difference between T-14 and T-15 bluesman423 Drivetrain 3 04-05-2011 10:09 PM
