| Chassis and Body Body, Interior, and Electrical, Frame... |
Dash Panel infoThis is a discussion on Dash Panel info within the Chassis and Body forums, part of the CJ Forums category; I am looking for some pictures of a dash panel for my 69 CJ5. It was changed around by the ...
Dash Panel info
12-12-2009, 01:22 AM
Vehicle(s): 69 cj5 V-6 93 YJ Rock Crawler
I am looking for some pictures of a dash panel for my 69 CJ5. It was changed around by the original owner and I want to put it Back to original.
Re: Dash Panel info
12-12-2009, 02:07 AM
72 CJ5 Owner
This might help - not sure if your exact year is in this post....
LINK -->> Different dashes what years are different
And an image from Morris 4x4...
Re: Dash Panel info
12-12-2009, 11:17 PM
Vehicle(s): WR450F, 68' CJ-5, 72' CJ-5, F250 POWERSTROKE
My 68 looked like that except it didn't have part#'s 4a-f, and 18 (knobs) The steering column was also mounted to the bottom of the dash(manual), instead of in the center-left. I purchased a dash on craigslist that maches the one cj sent. I was told it was for a 76-? It worked better for me since my 68' has been converted to power steering and is now mounted center-left. CJ, where can I buy part #'s: 4a-f, and the knobs. what are they for, and how much linkage/wiring is required to but those on my dash. I already have the holes there, and I want to fill them. Sorry for highjacking. ujoint- let me know if you're looking to sell those parts I mensioned.
Re: Dash Panel info
12-13-2009, 12:01 AM
I'm pulling my hair out. What I thought would be easy to find on line, turns out to be near impossible!  Can't find any pics of an original cj5 dash, that hasn't been altered. I may have my old dash still lying around. If I see it when I get home from work, I'll take a pic, and post it. Now it's got me wondering if my old dash was in fact stock or not.
Re: Dash Panel info
12-13-2009, 12:11 AM
Vehicle(s): 83'CJ-8 Scrambler Slightly Modified;), 67'Jeep M-725, 88'YJeep Wrangler Slightly Modified;)
Here's a 67' & a 75'
Re: Dash Panel info
12-13-2009, 02:56 AM
I found my old dash for my 68' CJ5. The black one is the one I purchased on CL that is supposed to be for a 76-? The red one is the original one I pulled off my cj. Notice the steering column mount on the bottom. PO had done a poor job of cutting a hole in the dash for the power steering conversion. Hope it helps.
Re: Dash Panel info
12-13-2009, 03:08 AM
#7
I think the one that Longhorn sent (67') Is what mine looked like at one time. I measured the two gauge holes above the speedo, and they're kind of off-center. I think someone added those after the fact.
Re: Dash Panel info
12-14-2009, 01:30 AM
#8
do you have any more pics of that 67 it looks great
Re: Dash Panel info
12-14-2009, 09:46 AM
#9
I think those are the only dash shots.
Re: Dash Panel info
12-14-2009, 10:57 AM
#10
Vehicle(s): 1977 cj-5
4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30,
skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road.
1981 J-10
4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
those are lighted labels for the different knobs. vent, heat, etc. there is one for the wipers and light switch as well. Find them on e-bay $25-$30 a set.
