Default Coil Resister
Old 07-07-2013, 02:26 PM   #1
dagr8tim is offline
dagr8tim
Vehicle(s): 75 CJ5, 232, T14, Dana 20, Dana 30, Dana 44 97 XJ, 4.0, AW4, 231J, Dana 30, C8.25
Images: 6
Rep Power: 7 dagr8tim is on a distinguished road
By the looks of the 77 232 in my CJ, it has a resistor before the coil. I get 12.8 volts into it and 12 volts out of the resistor. I'm not getting any spark and I suspect it's a bad coil.
A friend gave me an Accel 140001 (ACCEL brand | Part #: 140001) coil that he had kicking around from a waggy project he sold. I'm wondering if I need to run the resistor with this accel coil, or if I can run it straight off the ignition wire.
Also, I got the coil used with no adapter on top. How can I rig it up to fit the fitting on the wire from the distributor to the coil?
Hopefully this solves my no spark issue and and I can move on to the carb.
1997 Jeep Cherokee
1975 Jeep CJ5
Default Re: Coil Resister
Old 07-07-2013, 05:46 PM   #2
johnnyreb is offline
johnnyreb
Vehicle(s): 1980 cj5 258ci straight 6, 31x10.50's. Partial Teamrush iginition upgrade, MC 2150 Carb. 4.0 head swap, factory header. I call him "Eugene". Dad's jeep when he raced in the 70's. Cj2 running gear, ford 300 cu in 6 cyl with 3 deuces. Fiberglass model T body and hand laid fiberglass hood. welded 5.38 gears and beer keg fuel tank. see avatar Wife's: Black 04' Liberty with all the bells and whistles.
johnnyreb's Avatar
Images: 17
Rep Power: 8 johnnyreb is on a distinguished road
if the accel coil is threaded then you cut the wires and add rings terminals.
I call him "Eugene"
Old 07-07-2013, 08:51 PM   #3
If you are trying to do this on the cheep, I understand. BUT you are throwing good money after bad, pull the distributor out of the 77 and throw it as far as you can, replace it with a stock 1979 jeep distributor for a 258 and do the team rush ignition upgrade. then you can move on to the carb and not worry about the spark for a long long time. The 77 distributor is a piece of crap.
Old 07-08-2013, 11:14 AM   #4
johnnyreb
johnnyreb's Avatar
Images: 17
+1 on the team rush upgrade. I did most of it on mine.
I call him "Eugene"
Old 07-10-2013, 12:44 PM   #5
dagr8tim is offline
dagr8tim
Images: 6
There looks like there is a flat head screw down in the hole. Looking at product photo's online, it looks like it comes with a boot for the coil and nothing else.
I didn't realize that a remaned dist was only $44. I'll have to put that on my list.
Now as for the resistor, do I need to run a resistor with this coil?
1997 Jeep Cherokee
1975 Jeep CJ5
Old 07-11-2013, 01:13 PM   #6
Are you sure that you are looking at a resistor and not a capacitor?? Can we see a picture?
the 77 had no resistor.
the 75 may have , I guess.
coil , resister
MSD Blaster Coil Dirt Works Drivetrain 4 01-08-2013 07:40 PM
Coil question Al Lindner Drivetrain 3 09-21-2012 08:52 PM
How do I wire a coil on my 74 cj5 W/232? 74gator Misc CJ Discussion 6 06-27-2011 08:49 PM
new coil? Berg Drivetrain 1 02-22-2010 12:42 AM
Coil Correction Im Not Spam Jeep News and RSS feeds. 0 09-10-2009 05:22 PM
