Default Clocking a Dana 300 and new skid
Old 11-07-2010, 07:48 PM   #1
rockinthe4banger is offline
rockinthe4banger
Vehicle(s): 85 CJ-7 150 ci with T-4 in front of a Dana 300, 33s mounted on steelies with 2.5" spring lift plus 1" Currie Rock Crusher Shackles. 4.56s front and rear, locker up front
Rep Power: 0 rockinthe4banger is on a distinguished road
Question: I wanted clock my Dana 300 transfer case and build a new skid plate to increase my ground clearance. Has anyone walked down this road? If so, what potholes did you hit? Thanks for any help.
Default Re: Clocking a Dana 300 and new skid
Old 11-07-2010, 08:30 PM   #2
Vehicle(s): 83 CJ7 fiberglass body 350 tbi TH350 D300 twin sticked & clocked, narrowed Chief D44 Eaton Elocker, Ford 8.8 Detroit locker, 410's, 4" spring lift 1" body lift, 33" MTZ's for the road 35" claws on beadlocks for the trail. 6 point cage, Corbeau baja ulta seats, HD tie rod and draglink, u-bolts flipped, custom skids and sliders, Warn 9.5ti winch with Amsteel synthetic line, 95 Ram 2500 4X4 V10 (jeep hauler)
Images: 79
Rep Power: 10 Old Dog is on a distinguished road
Sorry I haven't made it to that road yet, it's still comming up sometime in the future.
Good luck and keep us posted.
Old 11-08-2010, 07:53 AM   #3
Vehicle(s): 1983 cj7,1971 Dart,2010 SRT8 Challenger
Images: 55
Rep Power: 7 gert will become famous soon enoughgert will become famous soon enough
The only thing I know about it is it either takes money or a drill press....the money part is the clocking ring that shortens your rear driveshaft by an inch or the drill press method which is best accomplished with a disassembled transfer case I am headed after the second method since I have a 3550 5 speed and my rear drive shaft angle sucks bad enough
Old 11-08-2010, 10:00 AM   #4
ThisGuyUKnow is offline
ThisGuyUKnow
Vehicle(s): 1982 cj7 limited 258/4.0 head/ax15/D300/3.54 gears, trac loc amc20,2002 Honda vtx1800c
ThisGuyUKnow's Avatar
Rep Power: 4 ThisGuyUKnow is on a distinguished road
Hey gert have you tried test fitting a D300 to your nv? I had the aluminum input housing from a 300 and it seemed to fit in the tail of my 3550 just fine. If I recall correctly the d300 has a NP bolt pattern so it may bolt to your 3550 without any issues as long as you are maintaining passenger side drop.
I would go with a clocking ring to reclock your TC for the OP i have seen them for 60 bucks and they aren't quite an inch i think closer to 3/4 inch is what mine measured out to be.
1977 Cherokee Chief W/T (Chief Many Moons)-360, Motorcraft 4BB, QT, 3.54 gears, 32" BFGs
Old 05-19-2012, 11:47 PM   #5
seaharding is offline
seaharding
Vehicle(s): 1985 CJ-7. dan 30 front with lock right and 3.73 gears rear amc 20 detroit, and 3.73s 4.2 with howell tbi dana 300 t-something or other tranny.
Rep Power: 0 seaharding is on a distinguished road
i would like to know what all it takes to do the clocking. i have herd that the drive shaft will be of to one side and I'm not sure of the belly up style skid to make or if i can buy one.
Old 05-20-2012, 07:48 AM   #6
Images: 79
you will need a clocking ring, you need to bend the shifter, enlarge the hole for the shifter, and a cv driveshaft as the angle will be to much for a reg. driveshaft. You usually need at least a 1" body lift and I had to cut one of the ears for the shifter bolt off.
I don't know if anyone makes a belly up skid for a cj. I made my own crossmember with 2 seperate skids for the transfercase and trans.
Old 05-20-2012, 10:32 AM   #7
seaharding
2 skids. great idea. thanks for the info. is advaced adapters the only clocking ring?
Old 05-20-2012, 12:20 PM   #8
Images: 79
There is a few places that make them. Novak and JB come to mind with JB's kit that comes with a new input shaft being the best.
JB Conversions, Inc.
I had an adapter for the TH350 to D300 in mine so I just redrilled it @6* the frist hole in the rings is usually 7*.
I'm taking my rear skid off now to get at the u-joints, I'll snap a couple pics of my crossmember and post them later.
Old 05-20-2012, 12:26 PM   #9
seaharding
cool. thank you.
Old 05-20-2012, 03:59 PM   #10
Images: 79
since I have a chevy drive train with a D300 t/c mine will be different than yours but here's what I did.
The crossmember is a piece of 2X3 tube and the skid plates are 1/4" plate.
The crossmember has the trans. mount and the skids bolt to the frame seprate so they can be taken down to work on the t/c or trans. without taking the trans down.
They now hang down 1 1/4" below the frame, maybe not flat but alot better than before.
The rear skid is off in the first and last pic.
The Following User Says Thank You to Old Dog For This Useful Post:
Jeepman85 (07-28-2012)
300, clocking, dana, skid
Clocking driver007 Drivetrain 9 09-07-2012 10:33 PM
JK Skid Plates Im Not Spam Jeep News and RSS feeds. 0 03-09-2012 10:21 AM
CJ5 skid plate 76CJ5 Chassis and Body 4 04-26-2010 08:55 PM
79 cj5 skid plate radman Chassis and Body 9 05-03-2009 10:26 PM
Skid-Free Im Not Spam Jeep News and RSS feeds. 0 04-14-2009 06:23 PM
