Default Brake Booster Upgrade CJ7
Old 02-09-2013, 02:56 AM   #1
JAG811 is offline
JAG811
Vehicle(s): '57 CJ6 & '78 CJ7
JAG811's Avatar
Images: 5
Rep Power: 8 JAG811 is on a distinguished road
A fair way back now I ordered an after market booster and master cylinder for the CJ.
Now, it's not as simple as just bolting it in so I thought I'd put together a thread so that others can do the same if they to have no power assisted brakes.
Things to consider.
  • Size of the booster.
  • Clearance from the hood.
  • You'll also need some new lines as the booster, and or the extension brackets will push the master cylinder forward.
  • It's not a direct bolt on job.
Pic 1 - So I ordered an 8" booster and master cylinder straight off ebay.
After taking some measurements and messing around a little I was positive it wouldn't foul on anything.
CJ7 - 78 Renegade Restoration in Progress
and a JK Unlimited
Default Re: Brake Booster Upgrade CJ7
Old 02-09-2013, 04:00 AM   #2
JAG811 is offline
JAG811
JAG811's Avatar
Images: 5
1. You'll need to undo the pedal linkage from inside the cab.
2. Then undo the two master cylinder bolts to loosen it.
3. You'll need to then look at tracing the two lines down to the Brake Proportioning Valve and undo them from there.
These will almost always give you difficulty and I had to use Vice Grips after purposely buying a high quality pipe spanner, that still looked as though it would have spun the edges off (strip) the nut.
4. Then you can remove the master cylinder - Brake lines still attached.
It's probably important to remind everyone I'm Down Under and so yes, it's all on the wrong side
and a JK Unlimited
Old 02-09-2013, 04:17 AM   #3
JAG811 is offline
JAG811
JAG811's Avatar
Images: 5
Once removed you'll need to take the Brake Booster Assembly and start to measure out on the firewall where you'll need to drill some holes.
Pic 1 - I marked the firewall horizontally across the two original mounting holes to assist with keeping the new assembly horizontal.
Pic 2 - I also marked the booster brackets to allow me to hold the whole assembly against the firewall to assist with locating, centre punching and drilling of the first hole.
Pic 3 - With just the one hole drilled, you can mount the assemble, so as to mark the other three holes that you'll need to drill out.
Pic 4 - Understanding the body on my CJ needs some attention. And so the (Aussie) drivers side sits lower then it should by about 3/8 of an inch.
So I lifted the body slightly to correct it to where it should sit, after I've looked at fixing that body mount. The trusty old level was used to make sure I was happy with where the master cylinder would finish up.
and a JK Unlimited
Old 02-09-2013, 04:34 AM   #4
JAG811 is offline
JAG811
JAG811's Avatar
Images: 5
Once all four holes were drilled out and the assembly test fitted, it was obvious that the Booster Assembly Mounting Brackets were going to cover the square hole the accelerator cable moves through.
So I marked enough room to get it through and with a 4" grinder cut in a nice half circle, and then had to respray the bracket.
and a JK Unlimited
Old 02-09-2013, 02:40 PM   #5
alpha6 is offline
alpha6
Vehicle(s): 1985 CJ7. Lifted 1.25; nutter bypass; MC2150, Team Rush Upgrade with a MSB A6 Ignition Mod.
alpha6's Avatar
Rep Power: 6 alpha6 is on a distinguished road
And?? does it work? Come on Jon...don't leave us hanging. Also...I am starting to think you actually have the wife doing all your work...no way your hands can stay that clean working on the jeep.
"If it's heavy, you need to get STRONGER!"
Old 02-09-2013, 04:28 PM   #6
thiswontbetooexpensive is offline
Vehicle(s): 1980 CJ5, Stock and original 258I6, Dana 300, T 176 (poor thing needs a little bit of time and a few kind words)
thiswontbetooexpensive's Avatar
Images: 74
Rep Power: 7 thiswontbetooexpensive is on a distinguished road
IDK about Jon, but I will only let the kids help me with my jeep. As far as my Wife is concerned, this is the most complicated thing a man can undertake and it requires hours of intense concentration assisted by copious amounts of cold beer!
Look great BTW. I'm going to have to print your build thread and keep it close when I get back at at...
Old 02-09-2013, 04:36 PM   #7
JAG811 is offline
JAG811
JAG811's Avatar
Images: 5
I'll try to have all of the pedal linkages sorted today.
And hopefully the lines will be next weekend.
I was taught by one of my supervising mechanics once, "A professional stays clean and keeps the vehicle clean". But he hated the stigma of mechanics are all covered in grease 24/7.
and a JK Unlimited
Old 02-09-2013, 05:41 PM   #8
alpha6 is offline
alpha6
alpha6's Avatar
So you are saying looking like this makes me a poor mechanic? Good luck getting those lines hooked up today.
Old 02-16-2013, 07:03 AM   #9
JAG811 is offline
JAG811
JAG811's Avatar
Images: 5
Pulled everything off to get to the pedal linkages and once I started putting it together I realised I was not going to be happy with the play in the "two washers and a split pin" they send you.
So I tapped the two pins so as to get a pair of nylock bolts on.
Given they're in the extension brackets, by some chance if they were to loosen up they couldn't fall off anyway- You'll notice it's pretty tight in there.
Mounting the assembly, and pedal linkages - Check.
Still have to look at the lines, and additionally, I'm fitting an adjustable proportioning valve, which means flaring lines to fit the different brake line fittings.
More pictures to come as I go.
and a JK Unlimited
booster , brake , cj7 , upgrade
Questions regarding the 1995 YJ Brake Booster upgrade. Rescue Diver Chassis and Body 2 05-25-2012 08:36 PM
Booster upgrade questions tevans59 Misc CJ Discussion 13 07-07-2011 08:41 PM
Brake Booster dalenelson Suspension and Steering 4 05-11-2011 12:44 AM
CJ brake upgrade - NOT YJ Power Booster wheelsdown Misc CJ Discussion 7 02-21-2011 12:08 PM
YJ booster/mc brake upgrade on a CJ? rumblephish Drivetrain 9 05-09-2010 09:03 AM
