| Chassis and Body Body, Interior, and Electrical, Frame... |
Boat sides?This is a discussion on Boat sides? within the Chassis and Body forums, part of the CJ Forums category; Sorry for the wait.The daves unlimited one was the way Im going. Here was the other I saw that seemed ...
Re: Boat sides?
04-28-2012, 02:24 PM
#11
Jeep-CJ.com moderator
Vehicle(s): 1981 CJ LAREDO. 258 , TF-999 with a Dana 300. 4in. spring lift with 35s and 1 piece rear axles.
1983 CJ-7 LIMITED. 258 awaiting a SM-465 with the Dana 300 T-case. Soon to go under a full frame off.
Sorry for the wait.The daves unlimited one was the way Im going. Here was the other I saw that seemed feasible.
YJ Boatside rocker kits - Pirate4x4.Com
Originally Posted by coldair
Ok when you find it post her up im still up in the air on this. its eather fix the rust or boat side it.
Re: Boat sides?
04-28-2012, 08:39 PM
#12
Vehicle(s): 1986 cj7 in the works, Rear axle dana 44, 33x13.50 toyo tires, built 258, Howell fuel injection, on board air, ford T18, twin stick Dana 300, Rasmey 9000 winch. Sold my 74 cj5
Both look good to me. i think i will go with the daves if i go this rought.
JEEP It's a way of life.
Re: Boat sides?
04-28-2012, 08:46 PM
#13
Vehicle(s): '77 CJ7 360/T18/D20 D60F/14bolt on 38's,
Stock '91 MJ 4.0/2wd parts runner
Originally Posted by Petescj
This one seems to include the front pieces where the other doesn't?
Re: Boat sides?
04-28-2012, 08:50 PM
#14
One thing to note the ones on the Pirate thread seem to enclose the cut away area in the front of the tub. Right at the firewall to keep it enclosed. I may change my mind.
Re: Boat sides?
04-28-2012, 08:51 PM
#15
Yup just took notice myself.
Re: Boat sides?
04-28-2012, 10:30 PM
#16
I didnt see that thanks for the heads up.
Re: Boat sides?
05-12-2012, 07:57 PM
#17
I just noticed the pirate boat sides you have to have a 1 inch body lift. I will be going with the Daves.
Re: Boat sides?
08-01-2012, 06:09 PM
#18
Thought I would bring this thread back. I want to see some picture of these installed  I've been dreaming all day long on how I can put these on my cj with the stock front fenders without cutting them up. Had a fellow Cj lover give me a good deal on a set that have never been installed.
Re: Boat sides?
08-01-2012, 06:22 PM
#19
I dont see them working with standard Cj fenders. Usually if you boatside a project standard body lines arent required.
Id cut off the bottom of the fender at the angle it meets the tub if you get my understanding.
Check this out
http://www.google.com/url?sa=t&rct=j...qjaxJBJcIolZQQ
Re: Boat sides?
08-01-2012, 06:26 PM
#20
That's the only way I could see it working too Pete. Maybe I need to get some tube fenders
