Default 1973 Frame specs
Old 10-23-2012, 09:14 PM   #1
1973 is offline
1973
Vehicle(s): 1973 CJ5, 258, 3 speed
Rep Power: 0 1973 is on a distinguished road
Can anyone tell me where I can find frame specs / measurements with a side view for a 1973 CJ5. I have located top views but can not locate a side view with the measurements. Thanks
Default Re: 1973 Frame specs
Old 10-24-2012, 12:44 AM   #2
Saddle Tramp is offline
Saddle Tramp
Rep Power: 9 Saddle Tramp is on a distinguished road
I believe that there is one in the old Chiltons Jeep CJ manual. By old I mean one of the smaller sized printings, not the newer ones that are the same size as the Hayes manuals. It could be in the newer one too but I donít have one to check. I have my house on the market right now so much of my reference materials are in storage to alleviate some of the clutter or I would scan it for you but maybe you can put your hands on one. Not sure where the frame shops get their specs but maybe an independent shop could help out.
Old 10-24-2012, 08:51 AM   #3
alpha6 is offline
alpha6
Vehicle(s): 1985 CJ7. Lifted 1.25; nutter bypass; MC2150, Team Rush Upgrade with a MSB A6 Ignition Mod.
alpha6's Avatar
Rep Power: 6 alpha6 is on a distinguished road
Is this what you are looking for? Sorry the thumb got in the pic I had to hold it flat.
"If it's heavy, you need to get STRONGER!"
Old 10-24-2012, 09:03 PM   #4
1973 is offline
1973
Thank you i will check the local library, they keep a section of those.
Old 10-24-2012, 09:10 PM   #5
1973 is offline
1973
Thats what I need just need the pre 76 version. I was told that 72 - 75 were identical frames with straight rails. I found top view with measurments but can not find a side view which is what I really need. Thank you for these ones, do you know if the side view / measurments would be the same for all 70's cj's?
Old 10-25-2012, 01:06 AM   #6
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 12 mylittlecj5 is on a distinguished road
This doesn't have the measurement call-outs, but it does show the way the frame is designed. maybe you can work with it some?
http://oljeep.com/gw/74_76_supplements/GROUP_11.PDF
Old 10-25-2012, 05:32 AM   #7
1973 is offline
1973
That will be very useful, thanks.
1973 , frame , specs
1973 Frame Swap and... dunebuggy18 CJ Build Forum 16 03-25-2014 12:29 AM
Fluid specs Bog Dog Drivetrain 4 03-31-2013 04:19 PM
'69 CJ5 Front Alignment Specs IowaCJ5 Suspension and Steering 1 03-20-2013 10:47 PM
Specs?? jwill22 Drivetrain 0 06-14-2010 08:51 PM
Torque specs surfbum Suspension and Steering 1 04-11-2009 07:32 PM
