M100 1/4 ton Jeep trailerThis is a discussion on M100 1/4 ton Jeep trailer within the Jeeps other than CJ's forums, part of the Jeeps other than CJ's category; This is my 1951 M100 1/4 ton Jeep trailer. I picked it up a few years ago
and redid it. ...
03-10-2010, 09:56 PM
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 30 LS Dana 44 locker 3:73's,4"lift ,1" body.York OBA,
Warn 8274,Fullcage.
and redid it. Same wheel bolt pattern as a CJ.
It was in sad shape. I'm thinking of painted my CJ7 the same olive green.
Re: M100 1/4 ton Jeep trailer
03-10-2010, 10:51 PM
Vehicle(s): 1979 Jeep CJ5 with 304 V8, T18 Tranny, Dana 20 Transfer case, 4.88 gears front and rear, Detroit TrueTrac up front and Ox Locker in back with 1 piece axle shafts, 35" BFG
Nice trailer.
I want one.
You did a good job on it. Did you change the trailer hitch? Wasn't it a pintle hook?
03-11-2010, 07:39 AM
Vehicle(s): '71 CJ-5, '78 Z1-R, '06 F-350, '07 Edge, '07 BSR
Good looking trailer!! Any detailed pics available for the hitch set-up? I've got a BT3-C that I want to replace the 1-7/8" Fulton hitch on with a 2" unit and extend the tounge a bit...
Daily driven: 1971 CJ-5; Dauntless V-6, Pertronix ignition, T-14 w/ Warn, 4.88 gears, Sag P/S, full cage, 3" lift, 33" MTR's. Old school USA iron with alot of class!!
03-11-2010, 08:45 PM
Warn 8274,Fullcage.
As I said the trailer was in sad shape. someone replaced the hitch with a ball type. I replaced that with a 2" ball setup. A M100 should not have a tailgate but this was cut in and I added the CJ tailgate and a new upper lip. Other trailers to look at are the 416 square fenders.
03-11-2010, 11:08 PM
Warn 8274,Fullcage.
Some more shots. Before Oct 07 , Replaced the axle using CJ hubs ,POR the bed.
CJ7 tailgate.
