2007 Jeep Grand Cherokee CRDThis is a discussion on 2007 Jeep Grand Cherokee CRD within the Jeeps other than CJ's forums, part of the Jeeps other than CJ's category; I'm very, very close to talking my wife into letting me trade my XJ on this '07 CRD WK.
I've ...
02-07-2010, 02:28 PM
Modded Jeeper
Vehicle(s): 1978 CJ7 258 w/ smog equip. removed, Autolite 2100 carb swap, Summit Racing street & strip ignition and coil, Optima yellow top, Flowmaster 40. Dana 30 front w/ Warn lock-out hubs, T-18A trans, Dana 20 t-case, AMC 20 rear. Everything else is stock, except the driver who is highly modified.
I've been doing a lot of reading of reviews online and everyone has good things to say about the CRD, but I don't know anyone that actually has one. Do any of you guys?
1978 CJ7 golden eagle
Re: 2007 Jeep Grand Cherokee CRD
02-09-2010, 07:15 AM
72 CJ5 Owner
Nope, but nice looking Jeep!
02-09-2010, 08:04 AM
Modded Jeeper
Type: 3.0L DOHC 24V V6
Construction: Sleeved aluminum block and heads, balance shaft
Valvetrain: Double overhead cams with hydraulic roller followers; four valves per cylinder
Bore & stroke (in): 3.27 x 3.62
Compression ratio: 18:1
Max hp @ rpm: 215 @ 3,800
Max torque (lb-ft)@ rpm: 376 @ 1,600-2,800
Injection system: Direct high-pressure Bosch, with pilot injection
Oil capacity (qt): 10
Coolant capacity (qt): 14
Emission controls: Oxy-catalyst, diesel particulate filter, Lambda sensors, and EGR
