Default what year is my cj
Old 02-29-2012, 08:50 PM   #1
jhall is offline
jhall
Vehicle(s): 77 cj5 newly bought ,stock 79 cj5 fiberglass body axles and springs from a k5 38/12.5 super swampers inline 6
Rep Power: 0 jhall is on a distinguished road
OK SO I BOUGHT A 77 CJ5 304 v8 well the day after the cam gear striped out well as i ordered parts for a 77 nothin matched up every thing for the motor was 73 parts then went to replace front wheel bearings and the ones i bought were for a 77 but they did not fit to big? the jeep does have drum breaks up front which i thought they quit using in 76?? the tag on the dash and firewall looks like it has been replaced. someone mentioned the numbers on tail lights would give you the year is this true? i also ordered a 4 in lift for a 77 and now wonderinf if its older will it fit?? any ideas??
Default Re: what year is my cj
Old 02-29-2012, 09:18 PM   #2
Rep Power: 17 IOPort51 is on a distinguished road
check your VIN and block number ??
Old 02-29-2012, 09:22 PM   #3
billyocup is offline
billyocup
Vehicle(s): 75 CJ5 304V8 T15 D20 D44 D30 2 1/2" lift, 05 Victory Kingpin, 2011 GMC Sierra 3500 Diesel 4x4
billyocup's Avatar
Rep Power: 9 billyocup is on a distinguished road
I'm surprised with your problems with the engine. I was under the impression that the AMC 304 was pretty much the same for every year from 72 to 81. I know that the frame and suspension changed in 76. The frame changed shape some and I believe the springs got wider. I think the shock mounts were also in a different location after 75. I'm certainly no expert though, so maybe some one with a little more knowledge will chime in.
Good Luck
Old 02-29-2012, 09:26 PM   #4
jhall is offline
jhall
the vin matches the title tryed to search vin but come up with nothing the casting numbers on block near the mount only says 304 found casting numbers on the head and when i research those i find several diff years that match that number from 70 to 81
Old 02-29-2012, 09:31 PM   #5
jhall is offline
jhall
Good Luck
i belive your prob right for the most part as the timing chain kit was for all those years as was gears but when it came down to replacing coil,cap,button,points and voltage reg. the 77 parts didnot match up had to get for a 73
Old 03-01-2012, 01:59 AM   #6
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 12 73CJ is on a distinguished road
Pre 76 had straight frame rails. 76 up flared in the rear.
Pre 76 springs were 1-3/4" wide.
Put some pics on and we can see rather than guess. A pic of the VIN plate would also help.
Old 03-07-2012, 12:37 PM   #7
1986cj7 is offline
1986cj7
Vehicle(s): 1986 cj7 258, t-176 4-speed, d-300, moser one piece axle in back in amc 20,G2 4.10 gears front and back, detroit truetac front and back,G2 4340 chromoly front axles in a d-30, 4" rough country lift, 33" tires
Images: 13
Rep Power: 8 1986cj7 is on a distinguished road
Try this site to decode your vin number,Decoding Jeep CJ VIN Numbers 1971-1986 Jeep CJ-5 CJ-7 CJ-8 | jeepfan.com I found this in another post (amc code is confusing me). I don't know if it will help but its worth a shot.
Old 03-07-2012, 12:55 PM   #8
Incommando is offline
Incommando
Incommando's Avatar
Rep Power: 8 Incommando is on a distinguished road
With how often Jeeps got modified I am shocked that many CJ's still have anything original left on them
Old 03-07-2012, 04:34 PM   #9
ken98k is offline
ken98k
Vehicle(s): {1980 cj-5, 258, t-176, d300 amc20 rear, D30}{1974 cj-5, 304, T-15, D20, D30 front, D44 rear}{1973 cj-5, 304, t-98,D20, amc20, D30} {1990 yj 2.5L i-4 AX-5 NP231 Dana 30 front Dana 35c rear} 1996 XJ Cherokee 4.0 HO {2000 silverado} {1979 Cadillac Sedan DeVille}
ken98k's Avatar
Images: 5
Rep Power: 9 ken98k is on a distinguished road
Wasn't 76 when they boxed the frame also?
year
help with year I.D. jeepboy45 Jeeps other than CJ's 8 03-06-2012 05:33 PM
what year top? rr41mag Chassis and Body 7 03-01-2012 09:43 PM
1 year Cheepjeep85 Sand, Dirt and Mud 9 02-05-2011 11:14 PM
Cj5 year?? Please help stuch71cj5 Chassis and Body 16 12-31-2009 02:17 PM
