Default starter solenoid and relay
Old 08-09-2011, 08:22 PM   #1
84Cjseven is offline
84Cjseven
Vehicle(s): 84 CJ7 with 2.5 liter 4 cylinder. T4 and dana 300. Tow vehicle 08 F250 Powerstroke 4x4
84Cjseven's Avatar
Images: 5
Rep Power: 0 84Cjseven is on a distinguished road
I just purchased this and the PO did some major hack work. One of the things that he did tell me though was he bought a starter solenoid, and believes he wired wrong and fried it. Well today when I got around to looking at it there is also a relay of some sort wired into it as well that also appears to be messed up as it just buzzes. Is this factory? Or did this go to something else and can be deleted? Also is this even the right solenoid? Reason I ask is there are three wires in the factory harness that look as though they should all be used (they have little boots that hook to the post) and there is only two places on this solenoid to hook them up. Any help would be appreciated. here are some pics.
Default Re: starter solenoid and relay
Old 08-09-2011, 08:31 PM   #2
CJ is online now
Images: 219
That relay is not factory. Can you trace the wires?
Old 08-09-2011, 08:37 PM   #3
84Cjseven
84Cjseven's Avatar
Images: 5
I guess I can take the wire loom off and try. It doesnt have any other accessories at all. I know it used to have a winch. I wonder If that could have been for that. Also according to advance auto the starter solenoid looks just like the one on my jeep so I guess its right. I just dont know what the 3rd wire with the boot is
Old 08-09-2011, 11:07 PM   #4
The relay is wired to the battery end of the starter solenoid.
Electrically it has nothing to do with the starter or it's solenoid. It's just an accessory that the PO had to wire up to the battery. When it is energized it takes 12 volts from the battery and supplies power to who knows what.
Actually it doesn't look like it is doing anything any more. I see ground hooked up. I see a wire going back into the wire loom. That's not enough wires to actually turn on anything.
Double-check to make sure I am looking at it right. If there are only 2 wires on that relay then it isn't in use any more. Disconnect those 2 wires and you won't notice any difference.
EDIT: What I mean to say is there are only 2 connections to the relay. The ground connection has 2 wires. Then there is a 2nd connection that goes back into the wire loom. Disconnect those 2 connections and you won't notice any difference.
Old 08-10-2011, 08:29 AM   #5
84Cjseven
84Cjseven's Avatar
Images: 5
Thanks guys. Anybody have a good diagram for the wiring. If not im heading out in a bit to pickup a chiltons
Old 08-10-2011, 08:59 AM   #6
Old 08-10-2011, 09:06 AM   #7
CJ is online now
Images: 219
Chiltons is a last resort for wiring. You really need a FSM.
Old 08-10-2011, 09:16 AM   #8
Just yesterday someone (don't remember who) posted this link of a great wiring diagram:
PROSPERO'S GARAGE Presents:* 11" x 17", Laminated, Full Original Color Wiring Diagrams for Motorcycles & Vintage Sports Cars!
Old 08-10-2011, 10:45 AM   #9
these are great!! water proof, washable, and in living color. and twice the size of a Chilton/Haynes.
Old 08-10-2011, 11:53 PM   #10
84Cjseven
84Cjseven's Avatar
Images: 5
All went well, it fired right up after the new solenoid.
relay , solenoid , starter
Starter Solenoid Issue. dedeye Chassis and Body 16 06-05-2013 01:54 PM
solenoid or starter issues willycj Drivetrain 4 04-30-2012 10:52 PM
1982 cj starter solenoid problem strathmaster4x4 Drivetrain 5 01-22-2012 08:42 PM
Starter Solenoid Casuall454 Drivetrain 12 09-28-2011 05:13 PM
name this starter solenoid! Germy Chassis and Body 4 07-12-2011 06:28 PM
