Default NOt getting gas from gas tank
Old 03-27-2010, 06:10 PM   #1
heretooiam is offline
heretooiam
Vehicle(s): 1983 Cj with 258 six
Rep Power: 0 heretooiam is on a distinguished road
I have a 1983 cj 7 jeep, when I brought it ,the old carb was junk, and
it had set for about a year. I got it running but had to put another carb
on it, it ran pretty good, but my problem is after it set for a few days
I can't get gas to the fuel pump. I've replaced the fuel pump,fuel filter,
carb ( used ) , even with priming carb it won't get fuel. Just to be sure
I've put more gas into the tank. Now thinking maybe the pickup in tank
is bad?, any Idea's ? thanks Mike
Default Re: NOt getting gas from gas tank
Old 03-27-2010, 07:18 PM   #2
CoreyYoungCj577 is offline
CoreyYoungCj577
Vehicle(s): 1977 cj7 232 inline 6,Dana 20 Tc,T-150 Trans, stock diffs.
Images: 18
Rep Power: 9 CoreyYoungCj577 is on a distinguished road
Replace the fuel sending unit? lol my tank is steel and i cant replace anything in it and i cant wait to upgrade it to my 84 gas tank, plastic with a skid plate. and i can take the sending unit out!
Old 03-27-2010, 07:31 PM   #3
Your sending unit will come out, you just rotate the retainer ring. I thought you had it out when you drained the tank.
Old 03-27-2010, 07:34 PM   #4
I would have to figure the pick up screen was the problem, try blowing in the fuel line and see if there is resistance, if nothing else you will blow it clear and it will work for a while. then you will know it is the screen.
Old 03-27-2010, 09:25 PM   #5
brian613 is offline
brian613
Vehicle(s): 77 CJ5 amc 304 Np 434 tranny twin sticked dana 20 transfer scout II dana 44's locked front and rear with 4.88 gears
Images: 6
Rep Power: 9 brian613 is on a distinguished road
I've replaced the fuel pump,fuel filte Mike
the only things left are the fuel lines and the sending unit. like said above blow through the lines and if that works Replace the sending unit because it will happen again
Old 03-28-2010, 10:19 AM   #6
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 11 Sasquach is on a distinguished road
Not fun but you probably will need to drop your tank, remove the pick-up/sending unit, clean out tank, disconnect fuel line from pump, blow compressed air threw fuel line, reinstall with new screen on pick-up or replace pick-up unit and you should be good for another 27 years.
FYI the the pick-up has a plastic screen on the end to keep debris out of the fuel line and mine was disintegrated when I removed it.
Smile Re: NOt getting gas from gas tank
Old 03-28-2010, 11:08 AM   #7
heretooiam
Thanks everyone, for the help, I'am dropping the gas tank . MIke
Old 03-28-2010, 12:32 PM   #8
dslywalker is offline
dslywalker
Vehicle(s): 1983 CJ7,258,stock Original Owner
Rep Power: 9 dslywalker is on a distinguished road
Let us know how you turn out.
Good Luck Mike
Old 03-28-2010, 12:43 PM   #9
CoreyYoungCj577
Images: 18
Well I did not know that and it looked like there was a nice weld around the input and output holes of my tank, it just looked like a big steel box that no one was getting into so i didnt.
gas , tank
YJ Gas tank gert Chassis and Body 14 02-25-2018 09:46 AM
pressurised tank kbob Drivetrain 7 07-10-2011 09:34 PM
Gas tank woes archer2147 Chassis and Body 12 06-14-2011 09:56 PM
gas tank 59cj5 Misc CJ Discussion 4 07-23-2010 10:22 PM
gas tank Old Dog Chassis and Body 15 06-06-2009 08:35 AM
