Default New Jeep Owner Needs Help
Old 05-27-2010, 11:25 PM   #1
phinleft is offline
phinleft
Vehicle(s): 76 CJ5, 4.2 L, inline 6, everything stock
phinleft's Avatar
Rep Power: 0 phinleft is on a distinguished road
I just purchased a 76 CJ5. Everything is stock except what appears to be an aftermarket distributor. It started and ran, but idled rough, and killed when coming to a stop. I tried to do the following minor stuff in hopes of curing the killing problem. After I completed the following, it turns over, but will not start now. I am very frustrated. Any suggestions?
- changed the positive battery cable because the terminal had cracked, and was hanging on
-changed the battery because the original one was bad
-changed all plugs and lines (plugs were gapped as specified 33-37), left all the lines in the same order
-Changed the seals on the carter 1bbl carb as they were cracked and crumbling - followed all instructions from carb kit, and did it carefully.
-checked the terminals on the distributor cap to make sure they were clean - didn't touch any other parts of distributor
After all of this was done, it turns over, but won't start. I am a novice to the timing, and don't know what to look for. Could that be it? Any help would be appreciated. getting very frustrated.
Default Re: New Jeep Owner Needs Help
Old 05-27-2010, 11:34 PM   #2
dslywalker is online now
dslywalker
Vehicle(s): 1983 CJ7,258,stock Original Owner
dslywalker's Avatar
Rep Power: 1 dslywalker is on a distinguished road
It'll help if you fill out your profile.Engine size/trany and transfer cases.Front and rear differental.
Do you have any spark at the coil wire or gas going in the carb,The carb would be my first guess since you worked on it.Unless something went wrong when you opened the distributor.Did you put the coil wire all the way in or it could be cracked inside.Try those things first Gas to Carb Spark on the coil wire when turning over.
Mike
Welcome to the site
83 CJ7 258
Howell TPI Injection
Old 05-28-2010, 07:28 AM   #3
priceg is offline
priceg
Vehicle(s): 1982 CJ 7 4.2liter T176,D300,D30,AMC20
priceg's Avatar
Rep Power: 1 priceg is on a distinguished road
Hello,I am a new jeep guy also. You need to back up a little bit and find the source of the problem before you start throwing parts on it. If you check the basics, you will discover your problem. 1,Fuel pressure. A 4.2 should have 4-5psi at idle and flow 1 pint in 30 seconds at idle. 2,ignition. Do you have pulse at spark plug? 3,timing, with number one cylinder at tdc on compression stroke, are both valves closed? 4,compression, a 4.2 needs between 120-150psi to run. These are the minimum specs your engine has to have to run. Once you establish what is missing, we can help you better diagnose your no start condition. I hope this helps, price g.
Old 05-28-2010, 10:25 PM   #4
phinleft is offline
phinleft
phinleft's Avatar
Thanks Mike, I will look into that. What is the best way to find all of the info to fill out my profile? New to jeeps, and not sure where to find engine, etc info on a 76 CJ5.
Old 05-28-2010, 10:31 PM   #5
phinleft is offline
phinleft
phinleft's Avatar
Price,
Thanks for the technical info to check. I will diagnose your suggestions. I had it running, and put a tune up kit and carb kit to try and correct the rough running. The plugs and lines hadn't been replaced in years according to the previous owner. I guess this is what I get for trying to make some improvements to the maintenance after buying.
Old 05-29-2010, 12:45 AM   #6
Trapshooter is offline
Trapshooter
Vehicle(s): 1979 CJ7, 304 w/HEI, T-150, Dana20, AMC20 rear, Dana30 frt. 1986 CJ7, 258, Team Rush, Nutter Bypass, T-18, D300, AMC 20 Locked Rear, Dana 30 Locked Frt.
Trapshooter's Avatar
Rep Power: 1 Trapshooter is on a distinguished road
phinleft.......have you tried pulling a plug and watch while someone cranks the engine to see if there is a spark?
Just pull a plug, short it to ground, crank engine, check for spark, its a quick and dirty check. If you do have a spark you can focus your efforts elsewhere.
The other thing that you can do is post a picture of your engine. You need to open an account at photobucket.com and upload your pictures to your account. Copy and paste the .img file into your post and the picture will load. We will be able to see just what you are working with.
Welcome to the wonderful and rewarding world of Jeep CJs!!
Hope this helps........
Old 05-29-2010, 11:53 AM   #7
priceg is offline
priceg
priceg's Avatar
Sounds like you are headed in the right direction. Once you determine what is missing, fuel, ignition, timing, or compression, you can check each component in that system untill you discover your problem. Remember, if you build a base line of tangible values, you will be able to plan for future repairs on weaker systems. Clear as mud?
Old 05-29-2010, 07:21 PM   #8
Modded Resident 'Old' Jeep Shaman
Vehicle(s): 67 cj5, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc front 11 inch drums rear,2 inch lift on 31s, custom seat, armored up 70 cj6 on stretched tj frame with Nth degree lift and all the goodies,33s 08 JK Rubicon with lift and armor
Images: 47
Rep Power: 4 BajaEdition is on a distinguished road
has either of you read the article
what to do after getting that CJ home
it is a basic article about getting the CJ ready for the road/dirt
follow it to get the CJ ready for modern service
Moderator in charge of putting foot in mouth
My Mouth Hurts
www.justgoodtrails.com
Old 05-29-2010, 10:33 PM   #9
phinleft is offline
phinleft
phinleft's Avatar
Baja, thanks for that article. That is why I joined this forum. Thank you to everyone for the help. I have solved the problem and got it running great. Turns out the only thing that I didn't change or touch was the choke. The coil in the choke was badly warped. Changed it, and set the rich/lean setting while running it in the neighborhood, and it runs great. On to make the headlights and brake light work, so I can get it inspected and road worthy.
Thanks again to everyone!
Old 05-30-2010, 02:00 AM   #10
priceg is offline
priceg
priceg's Avatar
I have read it and thought it was very informative. Have you authored any articles I need to read?
jeep, jeep cj5, not starting, owner
CJ-7 owner (new guy) rjowen33 Introductions 7 02-14-2010 09:38 PM
new owner of 79 cj5 crazymike Drivetrain 6 12-28-2009 05:09 PM
New guy...rookie Jeep owner. '85 CJ7 ne14soccer Introductions 7 12-02-2009 09:35 PM
New CJ owner how to Identify which jeep I have Inkslngr Misc CJ Discussion 8 10-24-2009 11:23 PM
Hi I am a new CJ owner! smithmyk Introductions 4 06-07-2009 11:30 PM
