| Misc CJ Discussion Forum for other topics not covered by the above forums. |
Let's see your interior upgrades!This is a discussion on Let's see your interior upgrades! within the Misc CJ Discussion forums, part of the CJ Forums category; Originally Posted by Cheepjeep85
ah you make a good point, i plan on adding some lights and a switch inside ...
Re: Let's see your interior upgrades!
03-06-2010, 12:10 AM
#11
Vehicle(s): 1977 cj-5
4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30,
skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road.
1981 J-10
4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
ah you make a good point, i plan on adding some lights and a switch inside on the dash for winch control when i get around to putting it on
did we talk about the winch switch on the dash idea??
The secret to flying? just throw yourself at the ground. and miss.
03-06-2010, 08:05 AM
#12
Vehicle(s): '74 CJ-5,
360 AMC Engine.
Accel HEI module/ TFI Ignition.
Holley Truck Avenger carb.
T-150 3 speed trans.
Model 30 Front diff. Drum Brakes.
Dana 44 rear diff (Lincoln Locked).
4" SkyJacker SoftRide lift.
2" lift shackles.
Front shackle reversal.
TJ fender conversion in rear.
35x12.50x15 TSL Super Swamper tires.
Optima Red-Top Battery.
Full Roll Cage w/ 4 point harnesses.
Custom Seating.
8000 Lb. winch on custom front bumper.
I put 3 small ammo cans between the tailgate and the rear seat, lined up, when we go wheeling. Keeps lots of stuff hidden since you can't really see them behind the seat back. I'm working on a way to lock them, but a tailgate lock would suffice for a while.
03-06-2010, 11:29 AM
#13
nope we talked about using the place where the radio was for a switch panel didn't we? if not i came up with a good idea on my own
"OK so I am sick and crazy because I feel closer to a machine than to 99.999% of the members of my species, I can live with that.  " IOPort51
03-06-2010, 11:59 AM
#14
Vehicle(s): 1978 Jeep CJ5, 2581v, t-18, t-20, amc 20, dana-30,
1964 CJ3B, 4-134
Here we go, Not exactly a groundbreaking idea but this what I did for now. Do want to find a little bigger can that is hinged though.
 1978 CJ5, 258 w/TFI, T-18, D-20, detuned Rubicon 4.5", Warn full float model 20 rear w/locking hubs, 31x10.5 on factory steel 15x8's
03-06-2010, 11:07 PM
#15
good grief that has to be one of the cleanest vehicles i've ever seen, a white floor and not a speck of dirt on it.
03-08-2010, 01:50 PM
#16
1981 J-10
Operating the winch from the drivers seat is not only difficult but can be down right dangerous. If you brake a cable it is coming right through the windshield. It is generally a good idea to be off to one side with the hood raised when you use the winch. It is also a lot easier to watch the cable on the drum from outside.
It is a little scary isn't it, too white!!
03-08-2010, 07:23 PM
#17
1964 CJ3B, 4-134
Ya, Ya, Ya, It is a bit much isn't it.
03-08-2010, 11:34 PM
#18
1981 J-10
It's OK, I just have never seen anything quite like it. Even on the way home from the carwash mine isn't that clean. If you can keep it that way I say "more power to you".
03-09-2010, 01:55 PM
#19
very, very clean, its not too much you just don't expect to see a jeep that clean. the winch switch will be a "backup" of sorts just in case for some wierd reason i need it
03-12-2010, 05:27 PM
#20
1964 CJ3B, 4-134
Now you gotta promise me know more white jokes OK? - Good
I have been looking to replace my stock seats and found these on the list that some guy bought to use as rear seats in his YJ, needless to say they were too wide and he was unable to return them. Fast forward..Now they are mine and after mounting them they sit really high to the point that I even removed my sliders to lose an inch.
Anyone with Mastercraft seats or others than had this prob? At this point I think I will make entire new seat mounts to get my slider back. They are really comfortable though and not ready to go back to the stockers.
