Default Re: electrical overload
Old 02-03-2012, 03:42 PM   #11
rigrunner567 is offline
rigrunner567
Vehicle(s): 1978 CJ-7 V8
Rep Power: 1 rigrunner567 is on a distinguished road
i had to pull the intake and the lights are on hold. it has some really old stewart werner gauges and both the volt and oil gauge go real high in numbers. ill post what i find when i get it running again. thanks
Old 02-03-2012, 04:04 PM   #12
Vehicle(s): 83 CJ7 fiberglass body 350 tbi TH350 D300 twin sticked & clocked, D30 Alloy usa axles Detroit truetrac, AMC20 Superior one piece axles Detroit locker, 410's, 4" lift 33" MTZ's for the road 35" claws on beadlocks for the trail. cage tied to frame, Corbeau seats, Hd tie rod and draglink flipped, u-bolts flipped, custom skids and sliders, Warn 9.5ti winch with Amsteel synthetic line, 95 Ram 2500 4X4 V10 (toy hauler)
Images: 73
Rep Power: 8 Old Dog is on a distinguished road
Originally Posted by CJ View Post
I'm guessing that the '60 volts' is a typo for '16 volts'. Never seen a volt gauge before that goes above 20 volts.
do you have as amp meter and not a volt meter in there. an amp meter will read both sides of zero.
Old 02-03-2012, 08:28 PM   #13
CJ is online now
Admin & Owner
Vehicle(s): '72 CJ5, V8, T18, D20, D44, D30 '82 CJ8
Images: 213
Maybe, an amp meter may read +- 60.
Old 02-05-2012, 09:29 PM   #14
rigrunner567
i was wrong. lol checked again it is volt meater. reads 12 when shut off and pegs the needle past 16 when running. gonna get the alt checked tommorow.
Old 02-05-2012, 09:59 PM   #15
73CJ is offline
73CJ
73CJ's Avatar
Images: 48
Rep Power: 5 73CJ is on a distinguished road
+16 volts sounds like a bad regulator.
Old 05-01-2012, 07:09 PM   #16
Turbogus is offline
Turbogus
Vehicle(s): '78 CJ 5 Renegade (Black Betty) '78 Kawasaki Z1R turbo (Go Fast) '81 Ford E 150 Panel van (Easy Bake)
Turbogus's Avatar
Rep Power: 0 Turbogus is on a distinguished road
When I wired up my Hella headlight shells so I could run high output H4 bulbs I wired in a relay for each side from the switch this way it wouldn't overload the circuit. I'm currently running 130/100 watt bulbs with no issues.
electrical, overload
Electrical Ballred82 Chassis and Body 2 06-05-2011 11:13 AM
Doing Electrical up grades ? Consider these fzsk4p Chassis and Body 9 01-16-2011 05:25 PM
Electrical help needed Jeepeagle Chassis and Body 3 05-28-2010 12:43 PM
Electrical Help Nwolford51 Chassis and Body 4 02-16-2010 12:53 PM
Need Some Electrical Help!!! 86 CJ Chassis and Body 20 01-17-2010 01:45 PM
