| Misc CJ Discussion Forum for other CJ topics not covered by the above forums. |
electrical overloadThis is a discussion on electrical overload within the Misc CJ Discussion forums, part of the CJ Forums category; picked up my 78 cj7 tonight and on the way home if i used my high beams all the lights ...
electrical overload
02-02-2012, 01:04 AM
Vehicle(s): 1978 CJ-7 V8
picked up my 78 cj7 tonight and on the way home if i used my high beams all the lights would go of. and on. And when i put the low beams back on every thing is fine. also cant turn on the heater blower motor with low beams on or same thing. anyone have any ideas as to what will cause this? thanks
Re: electrical overload
02-02-2012, 09:44 AM
Vehicle(s): 1986 cj7 258, t-177 4-speed, d-300, moser one piece axle in back in amc 20,G2 4.10 gears front and back, detroit truetac front and back,G2 4340 chromoly front axles in a d-30, 4" rough country lift, 33" tires
I would say its your dimmer switch. On mine the head lights would work in low but if you hit high beam they would go out. But the heater blower is new to me. Your lights and heater switch should be on differant circuits. I would try a new dimmer switch there cheap. Maybe someone else has an idea about the heater switch.
02-02-2012, 10:14 AM
Modded Jeeper
Vehicle(s): 1977 cj-5
4.2 W/MC2100 carb, 4.0 head W/3 angle valves,SS Header,TFI ignition with MSB-6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30,
skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road.8000 lb Warn winch, original owner.=^)
2006 Toyota Tacoma
Some how I think your going to find some field modified circuitry. those two things sort of pass by each other in the fuse block but are not related that I can see. upstream of the fuse block I would think the ignition would die as well as the lights. and then again, start by checking all the grounds, bad grounds account for 90% of CJ electrical problems.
02-02-2012, 06:32 PM
Vehicle(s): '86 CJ,258,T-18,D300,Dana 44s
'07 Grand(Wife's car)
I'm going to ask what voltage are you putting out to begin with. The lights and heater motor should be powered thru one of the fusible links coming off the battery side of the starter solenoid. Weak battery connections are a possibilty and you aren't putting out enough power for that stuff.
02-02-2012, 08:36 PM
thanks. ill check all connections soon. the volt reader is reading over 60 volts but show around 12 when not running.. but the oil pressur gauge is beside the volt meter and it reads over 80lbs and 60 at idle. after market antique guages.
02-02-2012, 08:43 PM
60 volts out of a 12v battery is a bit much, with the engine running it should be around 14.5. I would also suggest testing with a multimeter or something like that.
02-03-2012, 11:19 AM
#7
Vehicle(s): 1974 CJ5 ~ 304 V8 (DUI distributor upgrade with MSD street fire ignition box) - T15 Transmission - Dana 20 Transfer Case - Dana 30 Front Warn Prem. Lock-outs and 44 Rear Diff - 4.27 Gear Ratio's - Running 33" BF A/T Tires - Tilt / Power Steering - Hooker Super Competition Tuned Fenderwell Headers w/ Thrush "Super Hush" Mufflers and Stage 8 Locking Header Bolts - Warn M8000 Winch
 Something is not right there...
I had a similar problem, and it turned out My battery, and alternator, were both in need of replacement.
Sounds to me like you are running off your battery only, or the battery has some dead cells...
02-03-2012, 11:35 AM
#8
Modded Jeeper
2006 Toyota Tacoma
Digital Multimeter - Save on this AC/DC Digital Multimeter
this is a surprisingly good meter and doubly so for less than $20
if you don't have one I recommend you get one.
02-03-2012, 11:43 AM
#9
Admin & Owner
'82 CJ8
I'm guessing that the '60 volts' is a typo for '16 volts'. Never seen a volt gauge before that goes above 20 volts.
02-03-2012, 03:20 PM
#10
The headlights should be on a dedicated circuit. My headlights can be turned on even with out the ignition turned on. Could be that mine is wired wrong. I agree that if it was inadequate voltage the engine would cutout.
