| Misc CJ Discussion Forum for other topics not covered by the above forums. |
Caulking/Sealer HelpThis is a discussion on Caulking/Sealer Help within the Misc CJ Discussion forums, part of the CJ Forums category; I recently welded new metal in my floorboards where the roll bar meets the floor this is the place that ...
03-04-2010, 11:45 AM
Vehicle(s): Current Setup 1985 Jeep CJ-258, 6cyl -T-5 5spd 273 gears.
I recently welded new metal in my floorboards where the roll bar meets the floor this is the place that seems to rust real bad on CJ's which have carpet in them. I am looking for a good sealer to seal where the new floor boards meet the inner side of the jeep side, where the outer seat belt mount to.
Re: Caulking/Sealer Help
03-04-2010, 12:34 PM
Vehicle(s): 1978 Cj-5 1982 Cj-8 1985 Cj-7
I just bought automotive seam sealer when I did around the floorboards on my Cj-8. I also Herculined over it.
The Following User Says Thank You to Petescj For This Useful Post:
03-04-2010, 12:46 PM
Vehicle(s): 1983 cj7,1985 Dodge D250, 1971 Dart
I cant see Petescj's pics (work computer blocks em) but 3M makes a great brush on sealer that your local paint shop should be able to get
The Following User Says Thank You to gert For This Useful Post:
03-04-2010, 04:30 PM
Vehicle(s): '73 CJ5 232/T14/D20/D30/D44,
'74 CJ5 Renegade 304/T15/D20/D30/D44,
'85 CJ7 258/T5/D300/D30/AMC20
Acrylic latex caulk works great. It can be painted, and it's about as permanent as things get for vehicles.
-- Tim --
03-04-2010, 05:12 PM
Hi Tim, I just picked up some automotive sealer, going to give shot. Thanks for you help.
03-04-2010, 05:16 PM
 That'll work too.
-- Tim --
03-04-2010, 06:25 PM
#7
Vehicle(s): 1978 Jeep CJ5, 2581v, t-18, t-20, amc 20, dana-30,
1964 CJ3B, 4-134
I used Dominion sure seal it's OEM approved and comparable to 3m seam sealer I think there #8500?
Anyway it's not real easy to work with and you need to lay down a clean bead right out of the tube cuse it cures very fast and does not tool well.
I went thru 4 10oz. tubes priot to paint.
Every metal lap joint or crack that can hold water should be sealed if you are looking to rust free.
 1978 CJ5, 258 w/TFI, T-18, D-20, detuned Rubicon 4.5", Warn full float model 20 rear w/locking hubs, 31x10.5 on factory steel 15x8's
03-07-2010, 11:27 PM
#8
Vehicle(s): 1985 CJ7
Bedliner is definately the way to go.
03-11-2010, 03:11 PM
#9
Vehicle(s): 1968 CJ5 Cj7
After doing the seam sealer on mine I will be using the Raptor BedLiner Kit
03-13-2010, 01:29 PM
#10
Vehicle(s): '76/'79 CJ5, '00 cherokee, '94 YJ, '98 altima
I like to use E6000 it is made by the same people who make "Shoe Goo". It is self leveling and dry is slightly softer than bed liner. Being self leveling, to lay on an open crack or vertical surface a painters tape form or support is needed. it is the consistency of thick molasses so it will fill uneven cavities.
with 2200 miles of forest roads who needs the Rubicon
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
sealer and primer
andrea |
Chassis and Body |
11 |
12-13-2009 10:38 PM |
