Default temp gauge
Old 01-29-2012, 09:36 PM   #1
wadeo5247 is offline
wadeo5247
Vehicle(s): 1976 CJ7 304 V8 auto quadra trac, 2007 dodge mega cab 4x4 5.9 Cummings
Rep Power: 0 wadeo5247 is on a distinguished road
Hey I bought a new mechanical temp gauge for my cj7 (304) and it wont fit in the factory hole, my buddy said I can drill and tap the manifold, is this right if so where at, or do I have some more options. Thanks in advance
Default Re: temp gauge
Old 01-30-2012, 10:32 AM   #2
7D8CJ is offline
7D8CJ
Vehicle(s): 1978cj7 glass tub tilt front end 4.5" Rubicon Express lift 304 DUI Holly truck avenger T150 D20 33's , 2010 Rubicon JKU, 06 Mustang
7D8CJ's Avatar
Images: 46
Rep Power: 3 7D8CJ is on a distinguished road
I would say you have the wrong temp sender. Make it easy on yourself and get the right one. Try the stock one and see if it works.
****Wish I had more time and money****
Old 01-30-2012, 10:31 PM   #3
wadeo5247
I believe the factory one does work however the gauge is totally busted and useless, I also have elec. fans that I have to turn on manually so that's why I'm wanting to go with a mech. gauge plus it will give me accurate actual numbers
Old 03-05-2012, 10:24 AM   #4
shortbus is offline
shortbus
Vehicle(s): 1980 jeep cj7
shortbus's Avatar
Rep Power: 0 shortbus is on a distinguished road
go to napa, look at the brass fittings, sellect the one or ones you need, install, whalla! temp gauge.
Old 03-05-2012, 11:30 AM   #5
Vehicle(s): 84 cj7, 91 cherokee, 78 chevy 3500 pu
Rep Power: 1 mtnwhlr is on a distinguished road
So what you are saying is that the hole is to small? When I did this on the 454 IN my truck I used one of the drain plugs on the side of the block. you might want to try that.
gauge, temp
Water Temp Gauge Jeepers Creepers CJ Drivetrain 7 03-23-2011 07:41 PM
Fixing Gauge: Fuel and Temp northfaceboy22 Drivetrain 5 02-24-2011 08:04 AM
temp gauge desertrat78 Chassis and Body 5 07-20-2010 05:49 PM
Crown fuel and temp gauge bad out of the box rumblephish Chassis and Body 2 05-09-2010 01:20 AM
Temp Gauge Mort Misc CJ Discussion 7 04-25-2010 11:30 AM
