wheel joint?This is a discussion on wheel joint? within the Drivetrain forums, part of the CJ Forums category; i been fighting with the wheel joint on the driver side front of the jeep. its a d30. the first ...
wheel joint?
06-10-2009, 05:25 PM
Vehicle(s): 79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear, 2.5" procomp lift,teamrush,msd box,motorcraft carb,optima battery, ford shock towers.
i been fighting with the wheel joint on the driver side front of the jeep. its a d30. the first u joint i cracked a cap putting it in. the second joint i get on the axle and the caps stick out and wont let it slide through the spindle.  i guess friday i will go and buy our expensive one. i didnt want to get this one cause you can grease it. hopefully this one will be right. anyone ever have this with your wheel joint and where do you get them from. thanks.
you cant fix stupid. Ron White
Re: wheel joint?
06-10-2009, 07:43 PM
72 CJ5 Owner
I only buy Spicer u-joints (factory). I get mine from Morris 4x4 as they are one day shipping for me.
Now, I just had to buy some new axles for my CJ as I needed to change the u-joints and - since they had been in there for 30+ years they did NOT want to be removed. I ruined the axle trying to press the u-joints out so - replacement axles were needed...
If you want, I have two brand new in the box greasable u-joint (I just got from Morris) -->> Universal Joint Spicer Greaseable*8126637S-G I can send you. Let me know!
Re: wheel joint?
06-10-2009, 07:45 PM
Vehicle(s): '74 CJ-5,
360 AMC Engine.
Accel HEI module/ TFI Ignition.
Holley Truck Avenger carb.
T-150 3 speed trans.
Model 30 Front diff. Drum Brakes.
Dana 44 rear diff (Lincoln Locked).
4" SkyJacker SoftRide lift.
2" lift shackles.
Front shackle reversal.
TJ fender conversion in rear.
35x12.50x15 TSL Super Swamper tires.
Optima Red-Top Battery.
Full Roll Cage w/ 4 point harnesses.
Custom Seating.
8000 Lb. winch on custom front bumper.
If you havent got the caps at least flush with the axle material, its a good thing that it wont go in thru the spindle! It would self-destruct in a couple miles...Make SURE the caps sit flush in the axles! Also make double sure the axle area is clean, so nothing is hanging the caps up from sitting correct.
Re: wheel joint?
06-10-2009, 08:05 PM
dang cj that is a expensive joint. the highest price one at my work is 19.88 i will try that one first on friday when i get paid. then i will think about that one. im going to get a lift hopefully this weekend  and need to get this axle back in.
Re: wheel joint?
06-10-2009, 08:14 PM
72 CJ5 Owner
DF - I'll sell them for what ever - same price you can get the off brand ones for... If I don't sell them they go on a shelf probably never to be used again. The axles I ordered do not use them so they are worthless to me.
Send me a PM, I'll ship em out to you - if you can use them then when you have $$ send it... No hurry!
I hate to see good $$ throw after bad parts!
Oh yea, they are expensive but they will most likely last another 50 years and most of all - the FIT the first time!
Re: wheel joint?
06-11-2009, 05:13 PM
fit right the first time sounds good right know. lol. i am becoming a pro at popping those suckers in and out now and taking everything off the spindle.
Re: wheel joint?
06-13-2009, 10:57 PM
#7
DaleFan88s Supreme Master
Vehicle(s): 79 cj5
Glad my husband isn't the only one. He beat the ever living  out of the axles when the last u joint he tried would not come out. Then it went flying across the lawn.
Good times
Re: wheel joint?
06-13-2009, 11:02 PM
#8
72 CJ5 Owner
Good times
I'm rolling on the floor! We all know about those troublesome parts... CJes = WORK!!!
Re: wheel joint?
06-14-2009, 06:23 AM
#9
Well, do not laugh right now!
Take coke to get these rusty not moving parts going.
When I hear that years ago, but -believe me or not- Coca Cola dropped on a rusty nut, 15 minutes waiting time and you can get it. Even if it has not moved since 30 years.
Re: wheel joint?
06-14-2009, 08:25 AM
#10
360 AMC Engine.
2" lift shackles.
Custom Seating.
Coke also works to get grease out of your work clothes...But thats a whole 'nuthr thread!
