Default What is the best 4bbl carb for oddfire 225 V6?
Old 07-13-2012, 02:06 AM   #1
sweet66monza is offline
sweet66monza
Vehicle(s): 68 cj5 (currently under restoration), two 58 Jeep FCs, and 8 chevy corvairs
sweet66monza's Avatar
Rep Power: 0 sweet66monza is on a distinguished road
I am getting ready to fire up the fresh motor and have an aluminum 4 barrel intake installed, but no carb yet. What do you guys recommend for a good carb?
Default Re: What is the best 4bbl carb for oddfire 225 V6?
Old 07-13-2012, 12:55 PM   #2
Incommando is offline
Incommando
Incommando's Avatar
Rep Power: 7 Incommando is on a distinguished road
390 CFM Vacuum Secondary
Holley Performance Products 390 CFM Four Barrel Street Carburetor*0-8007
or you might try a 470 Truck Avenger
Holley Performance Products 470 CFM Four Barrel Carburetor*0-90470
but that may need some serious tuning to get to work on a 225. They are pretty popular for 360's even...
Old 07-13-2012, 03:21 PM   #3
derf is offline
derf
Vehicle(s): 1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress 1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress 1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
derf's Avatar
Rep Power: 8 derf is on a distinguished road
For a V6 like that I'd put serious thought into bolting up an adapter and running a 2bbl Motorcraft 2100/2150. Most 4bbl carbs are too big for an engine that size.
Old 07-13-2012, 04:13 PM   #4
jswatson0917 is offline
jswatson0917
Vehicle(s): 1979 CJ7 304 T-150 D20 D30 AMC20 2000 Subaru Outback Limited
jswatson0917's Avatar
Images: 49
Rep Power: 9 jswatson0917 is on a distinguished road
Send a message via AIM to jswatson0917 Send a message via Yahoo to jswatson0917 Send a message via Skype™ to jswatson0917
Old 07-13-2012, 04:15 PM   #5
I'm with derf also.
Old 07-13-2012, 04:43 PM   #6
tarry99 is offline
tarry99
Rep Power: 9 tarry99 is on a distinguished road
I've got a Holley 390 CFM 4 barrel on mine with the Offy manifold and it runs perfect. In fact that 390 CFM carb was built for the V-6 engines back in the day..........The Holley is one of the easiest carbs to work on and very easy to Jet..............
Put a good aftermarket aluminum manifold on it........ton's of torque!
Buy it you'll love it..............
Old 07-13-2012, 06:15 PM   #7
Incommando
Incommando's Avatar
IIRC the 2100 is from 300 to 450 CFMs depending on the original app so the 390 is isn't out of the ballpark. But if you are off-roading the 2100 is one of the best ever while Holleys in general have a rep for needing some work to excel off-road.
Old 07-13-2012, 08:09 PM   #8
tarry99 is offline
tarry99
Incom:
No doubt the MC 2100 is a good little 2 barrel Carb. with a good reputation.
On the other hand the little Holly 390 has done me a great job both at sea level & altitude. If there are some mods that your aware of please pass them on I would be interested. Also, If I already had a 4 barrel manifold personally I would probably stay away from the adapter. Just my Opinion.
Old 07-13-2012, 09:38 PM   #9
Resident 'Old' Jeep Shaman
Images: 141
I have never had any luck with a 4 barrel on a 225 built for a jeep
maybe the marine version but the tourque is to low on the dauntless in the jeep version
put a big 2 barrel on it. the motorcraft one is great
Old 07-14-2012, 09:45 AM   #10
Incommando
Incommando's Avatar
Originally Posted by tarry99 View Post
Incom:
I wasn't trashing on the Holley just noting that it can be made better, especially for serious off-camber stuff and climbing/descending angles. I swapped an intake and a 390 onto a 231-powered Skyhawk and it really helped. As you know the 231 is the direct descendant of the 225. But that is a completely different app and intended usage.
There are dozens of sites with tips for improving a Holley for off-road. The 390 usually isn't mentioned but the same principles should apply. Just one example:
Offroad tricks for Holley 4 barrel carbs | ClassicBroncos.com Tech Articles
The mod most often mentioned is the vent tube.
My favorite 4-v ever for off-road is a Q-jet. They don't call them hillbilly fuel injection for nothing. The downside is that you would need an adapter for your intake and I doubt there is one small enough for for a 225.
225 , 4bbl , carb , oddfire
HEI for oddfire 225 v6? sweet66monza Drivetrain 2 11-13-2012 08:52 AM
4bbl to 2 bbl? rr41mag Drivetrain 7 09-21-2011 08:28 PM
4bbl carb ? plumcrazy Drivetrain 9 11-07-2010 06:04 PM
231 oddfire verse 252 even fire Dayle Drivetrain 4 07-07-2010 10:29 PM
