Default weber carb and fuel retrun line?
Old 08-05-2010, 10:05 PM   #1
stevr59 is offline
stevr59
Vehicle(s): 1985 cj7 258 6 t 176 4 speed Dana 300 4" suspension lift "upgrade".team rush ignition Weber 32/36 carb Holley fuel regulator new besttop top nutter bypass
stevr59's Avatar
Images: 20
Rep Power: 9 stevr59 is on a distinguished road
hey guys i got a 85 cj 7 with the strait six and replace the old carter carb with a weber and installed a holly fuel presser regulator..... what i need to know is do i need the return line? if so do i still use the stock filter or go with a single filter and hook the re trun line to the regulator..... as of now i got it hook up like the factory but jeep stars fine but cant drive it for 10 mins as it spits and sutters bad till its warmed up... all so it does it after it warmed up and u shut it down for a few mins.. it spits and sputter for a few mins it... idles fine. and i smell gas at start up so i am quessing its flooding... fixing to rig a presser gauge tomorrow and adjust the regulator to 3.5 psi but not sure what the best way to deal with the re trun line
Default Re: weber carb and fuel retrun line?
Old 08-06-2010, 09:55 AM   #2
Resident 'Old' Jeep Shaman
Images: 141
yes you need that return line, it is very important, all the way back to the tank.
Old 08-06-2010, 12:21 PM   #3
stevr59 is offline
stevr59
stevr59's Avatar
Images: 20
Ok cool then i keep the stock hook up then.... I just got done installing a pressure gauge on the regulator and try to adjust it to 3.5 psi but the gauge fluctuates badly from 3.5 to 0 is this normal or is my fuel pump going bad?
Old 08-06-2010, 05:14 PM   #4
LASTCJ786 is offline
LASTCJ786
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
Rep Power: 9 LASTCJ786 is on a distinguished road
Hold on ,I and my buddy don't run return lines on our CJ's (with Weber)both of us have a single line in and out filter. I like it better the gas stays in the filter for easyer starts.Plus I run a clear filter so you can see the gas in it.
The last CJ7 86
Old 08-06-2010, 07:20 PM   #5
stevr59 is offline
stevr59
stevr59's Avatar
Images: 20
did you cap off the re turn line or did you leave it open when u disconnected it
Old 08-07-2010, 03:37 PM   #6
LASTCJ786
I capped it off at the tank. It's been working fine since May.
The last CJ7 86
Old 08-08-2010, 06:54 PM   #7
stevr59 is offline
stevr59
stevr59's Avatar
Images: 20
will i desided to try the filter with out the retrun line for grins.... and soon as i fired it up the fuel pressure shot up to 5 psi and was steady, engine idle was way up had to re set the idle speed reset the fpr back to 3.5 and mixture and the fast idle was way up as well... not sure whats going on here or is it possible my brand new stock fule filter was bad right out of the box... with the stock filter my fpr pressure fluctuated from 0-3 psi now is that normal with the retrun line hook up to a stock filter running a mechanical pump
carb , fuel , line , retrun , weber
Fuel line modification for Weber carb failing Flex BT Drivetrain 3 03-19-2012 06:48 AM
Weber Carb Redman Drivetrain 2 02-11-2012 12:11 PM
Fuel Line, Pump to Carb al2ride Drivetrain 6 10-04-2011 12:02 AM
Please help with weber carb 84Cjseven Drivetrain 0 09-21-2011 02:29 PM
