Default Trouble Timing cj5
Old 08-10-2009, 08:01 PM   #1
Nixon is offline
Nixon
Vehicle(s): 76 CJ5 258
Nixon's Avatar
Images: 7
Rep Power: 0 Nixon is on a distinguished road
I am having a heck of a time with my Cj. It ran O.K. when I brought it home, but needed a tune up. I replaced wires rotor cap plugs etc. Set the carb mixture screws 1 1/2 turns out. When I went to time it, the marks were not even close. I got the marks to line up , but I had to turn the distributor alot. Needless to say it ran aweful, backfiring etc. I set it back close to where it was, it still backfires a little and is not running real strong. Seems hot too. Why would my timin marks be so off? Could the dist be off a tooth? Would that even make a dif? Thanks for any help.
Default Re: Trouble Timing cj5
Old 08-10-2009, 10:04 PM   #2
SemperFiCJ5 is offline
SemperFiCJ5
Vehicle(s): 1974 CJ5.
SemperFiCJ5's Avatar
Images: 27
Rep Power: 0 SemperFiCJ5 is on a distinguished road
What does your timing mark line up with on the degree scale?
Is your distributor cap cracked, not seated properly, same with your rotor.
Is there any chance that the spark plug wires are out of order?
What did you gap the plugs to?
Check vacuume lines
1974 CJ 5, 401 EFI, 35 Pitbull Rockers, SOA, Warn 8274
Old 08-10-2009, 11:21 PM   #3
kicknjeep is offline
kicknjeep
Vehicle(s): 1999 TJ, 1976 CJ-5 2 seater
kicknjeep's Avatar
Images: 20
Rep Power: 10 kicknjeep is on a distinguished road
I also would double check the firing order versus where you have your plug wires, it is not hard to cross wires when changing them out and if they are ok, and your cap and plugs are ok then this should get you in the right direction:
http://www.jeep-cj.com/forums/f2/pro...ghlight=timing
Old 08-11-2009, 06:46 AM   #4
Images: 219
Hello Nixon and welcome to our site!
I'm assuming you did not pull the dist - correct? If you did not, about the only way for the marks to be off so far is -
  • The cap is on wrong
  • The wires are on wrong
  • The rotor is on wrong
  • You have the timing light connected to the wrong wire
  • The advance mechanism under the rotor is locked or jammed
Old 08-11-2009, 09:05 AM   #5
DIG is offline
DIG
DIG's Avatar
Rep Power: 10 DIG is on a distinguished road
Retrace your wires and make sure you have them in the correct order, if so, I would just reset the time, in my experience with timing ( which is my weak point) a tooth off can make a hell of a difference!
Onecrazyblackredneck
1978 CJ-5 304 t176/dana 300 headman headers, purplpe hornies, holley 2barrel
Old 08-11-2009, 10:27 AM   #6
Resident 'Old' Jeep Shaman
Images: 141
what engine do you have? If it is an odd fire V6 you can really get things off with improper wire placement
Old 08-11-2009, 11:29 AM   #7
Nixon is offline
Nixon
Nixon's Avatar
Images: 7
Thanks guys for your help. I should have mentioned it is a 258 6cyl. I'm not sure the dist is in right. The guys I bought it from started tinkering and while he did put some nice parts into it, I'm sure he knew all what he was doing. I've spent alot of time straightening things out. The Vac advance looks new, so I'm guessing he did pull it out. I'm sure the firing order is right and the cap and rotor look fine. the timing mark is currently way to the left or counterclockwise of the scale. You can barely see it where it is at.
Old 08-11-2009, 11:34 AM   #8
Images: 219
If he pulled the dist and put it back in wrong - that is your problem. If you turn the engine over to Top Dead Center (the timing mark on the balancer at zero), is the rotor facing #1? If it is facing towards #6 then you need to turn the engine over 360 degrees.
Now that the rotor is some what facing #1, is it facing directly at the location for #1 on the cap? If not, you need to pull the dist and rotate the gear one tooth at a time until it is.
Old 08-11-2009, 02:42 PM   #9
I am having a heck of a time with my Cj. It ran O.K. when I brought it home, but needed a tune up. I replaced wires rotor cap plugs etc. When I went to time it, the marks were not even close. .
Nixon you say it ran ok when you brought it home.
If you didn't remove the dist... Are you sure your wires are on right.
Your timing chain might have jumped a tooth or two also.
Old 08-12-2009, 08:07 PM   #10
Nixon is offline
Nixon
Nixon's Avatar
Images: 7
Well, I'm about 99% sure My timing chain jumped. I guess I'll be tearing into it this weekend. On a better note, I'm sure it will ru much better. Thanks for all you guys help. Any tips? I'll let you know how it goes.
cj5 , timing , trouble
Clutch Trouble MarkSud Drivetrain 13 06-01-2014 06:43 PM
Brake trouble Rmullerkc Drivetrain 4 04-15-2013 08:17 AM
Tire trouble driver007 Misc CJ Discussion 10 04-12-2013 09:58 AM
AMC 20 trouble DRoss Drivetrain 3 01-10-2012 04:56 PM
Trouble Finding A CJ7 Hardtop jeffgtoman Chassis and Body 11 11-14-2011 04:53 PM
