Question Transmission keeps jumping out of first gear
Old 05-16-2012, 11:04 AM   #1
jswatson0917 is offline
jswatson0917
Vehicle(s): 1979 CJ7 304 T-150 D20 D30 AMC20 2000 Subaru Outback Limited
jswatson0917's Avatar
Images: 49
Rep Power: 9 jswatson0917 is on a distinguished road
Send a message via AIM to jswatson0917 Send a message via Yahoo to jswatson0917 Send a message via Skype™ to jswatson0917
When ever I am decelerating down an incline the transmisson will kick the shifter out of first gear. The only way to stop it is to force it back and hold it in place which is a challenge to keep there. My Jeep has a 304 with a t-15 transmission. Any ideas what the problem could be and how to fix it?
Default Re: Transmission keeps jumping out of first gear
Old 05-16-2012, 10:26 PM   #2
mtnwhlr is online now
Images: 56
Rep Power: 12 mtnwhlr is on a distinguished road
Sounds like it's time for a rebuild.
Old 05-17-2012, 12:37 AM   #3
VT Woodsman is offline
VT Woodsman
Vehicle(s): 1978 cj7 304 v8 , 4speed which i think is out of a newer cj. Im pretty sure it has a stock transfer case.
Rep Power: 0 VT Woodsman is on a distinguished road
Mine does it in second gear, and also has a whine in first gear
Old 05-17-2012, 12:55 AM   #4
Saddle Tramp is offline
Saddle Tramp
Rep Power: 9 Saddle Tramp is on a distinguished road
If stock (1979) the transmission should be a T150 not a T15. I’m not a transmission guru but a lot of things not inside the box can be related to popping out of gear from shot motor mounts, lack of a good transmission mount, and a missing or bad torque stud; could even be clutch misalignment. I would look at mounts or torque stud first before yanking the transmission.
Old 05-17-2012, 01:01 AM   #5
tarry99 is offline
tarry99
Rep Power: 9 tarry99 is on a distinguished road
Sounds like in both of those cases its a bad synchronizer, that's the part that allows you to shift between gears with no grinding.
Like the other person said , rebuild time.
Old 05-17-2012, 09:00 AM   #6
jswatson0917
Images: 49
Is a rebuild someone with a decent tech manual and some mechanical knowlege can do on his own or should I drop it and take it to a pro?
Old 05-17-2012, 09:06 AM   #7
jswatson0917
Images: 49
It has been my understanding that the 79s had both the CJs with a V-8 (like mine) hade the T-15 while the others had the T-150
Old 05-17-2012, 10:48 AM   #8
tarry99 is offline
tarry99
Js,
In answer to your question,Yes anyone that has common since and the ability to comprehend detailed instructions along with following the proper order of assembly can make it happen.
The only thing that may hold you up is time, and having some special tools, like pullers, a press and bearing drivers. If you have access to these things again by all means go for it, but don't use some backyard tools or approach to your rebuild that will come back to haunt you.
Old 05-17-2012, 03:39 PM   #9
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 10 JR74CJ5 is on a distinguished road
I had my T-15 rebuilt, and it still pops out of reverse often.
I like checking what Saddle Tramp suggested before jumping into a rebuild.
These t-15's are very strong tranny's.
and yes internally pretty simple.
After having mine professionally done, I seen the gear sets, and shafts, and kicked myself for not going ahead on my own. (especially since it did not solve the problems. (but my input shaft bearing was toast and balls missing so it did need attention)
~ JR
JR - ECV3
My Build< Click me
Old 05-17-2012, 03:53 PM   #10
JR74CJ5 is offline
JR74CJ5
JR74CJ5's Avatar
Images: 80
also the T-15 is a common swap to stock T150's.
T-15's "should" have only been stock options behind v-8's (but occational stock upgrades behind 6's) from 71-75.
Sources:
Our Info section (BusaDave's Post): http://www.jeep-cj.com/forums/f105/m...112/#post97086
Novak: The Borg-Warner T15 Jeep Transmission - Novak Conversions
Which reads:
Borg-Warner T15 Transmission
The Borg-Warner T15 is a medium-to-heavy-duty, three-speed transmission, introduced in the 1971 Jeeps. It was offered in Jeeps up through 1975. The T15 was primarily found behind the AMC V8 engines as the base transmission, but was also found behind the AMC 232 and 258 I6 engines as an upgrade option over the T14. The upgrade to the T15 transmission was the Jeep T18 four-speed."
Though anything with these fun jeeps is possible
~ JR
JR - ECV3
My Build< Click me
gear , jumping , transmission
Keeps jumping out of first gear... need help please. Airstrike Drivetrain 8 04-20-2013 11:14 AM
Manual Transmission keep jumping out of gear... Airstrike Drivetrain 3 12-02-2012 11:41 PM
Transmission won't engage when in gear BLennon Drivetrain 4 12-01-2010 04:21 PM
Puddle Jumping Im Not Spam Jeep News and RSS feeds. 0 02-05-2010 02:00 PM
Holy Jumping Jeeps! Im Not Spam Jeep News and RSS feeds. 0 12-29-2009 07:20 PM
