Default transfer case fluid
Old 08-08-2011, 05:07 PM   #1
jamie is offline
jamie
Vehicle(s): 76 cj 5 360, 999 tranny and dana 300 transfer case, dana 44 rear and dana 30 front diff
jamie's Avatar
Rep Power: 8 jamie is on a distinguished road
i have a dana 300 transfer case and am curious as to what fluid i should have in it. right now it has automatic trans fluid in it from the previous owner, but im unsure if it is supposed to be in there, or if its supposed to be gear oil. could this be part of my hard to shift into 4wd problem? if it is supposed to be gear oil, what weight should be in there, how much, and what is the best way to flush out the old trans fluid. im unsure of the year of the case, but its behind a 904 automatic transmission
evil will always triumph over good because good is dumb.
dark helmet
Default Re: transfer case fluid
Old 08-08-2011, 05:30 PM   #2
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 10 JR74CJ5 is on a distinguished road
Originally Posted by Novak
When filling your 300 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good.
From Novak's website here... The Dana Spicer Model 300 Transfer Case - Novak Conversions all the way at the botom, although all the info is good to read there...
JR - ECV3
My Build< Click me
Old 08-08-2011, 05:41 PM   #3
I use 80-90 GL5 in mine.
Try cleaning you shifter linkage, they get all gunked up over time. They also shift way better with a twin stick.
Old 08-08-2011, 08:32 PM   #4
CJim7 is offline
CJim7
CJim7's Avatar
Rep Power: 9 CJim7 is on a distinguished road
80W90
...And as stated, cleaning up the linkage will help immensly.
<img src=http://www.pixeldecals.com/shop/image/cache/data/flipoff_smiley_3c-400x400.jpg border=0 alt= />
Old 08-08-2011, 10:48 PM   #5
jamie is offline
jamie
jamie's Avatar
looks like i need some 80-90 gl5 and some good cleaning of the linkage. should i worry about flushing the case, or just open the inspection cover and wipe all the schmoo out
dark helmet
case , fluid , transfer
What Transfer case will fit! SCswampfox Drivetrain 2 04-14-2013 07:12 PM
What fluid should I use in my dana 20 Transfer Case w/auto th400? 76cj7chick Drivetrain 8 09-04-2012 07:42 PM
what type of fluid do you put in a transfer case mycapricess Drivetrain 7 07-31-2010 02:52 PM
transfer case cjnewbie Drivetrain 18 03-22-2010 12:59 AM
trans/t-case fluid ? BrockGrimes Drivetrain 12 09-08-2009 12:18 PM
