Default Timing Chain R/R
Old 11-07-2011, 08:16 AM   #1
phyrph0enix is offline
phyrph0enix
Vehicle(s): 1984 Jeep CJ-7 6cyl 5spd
phyrph0enix's Avatar
Rep Power: 8 phyrph0enix is on a distinguished road
Hey guys,
It's been a while since I've done any timing work. I was wondering if anyone knew a good Step-By-Step walkthrough of a CJ-7 258 timing chain and sprocket removal/reinstall? It sounds to me like though it's a fairly straightforward job, there are slight nuances that might cause the car to leak once I'm done (ex: dampener sleeve).
I'm pretty visual, so I'd love some pictures if it's not too much to ask... :P
Thanks guys!
Vince
Default Re: Timing Chain R/R
Old 11-07-2011, 10:21 AM   #2
phyrph0enix
Ok, ok... so maybe just a list of things I need to do/watch out for? I'd love to get this done today!
Default
Old 11-07-2011, 01:12 PM   #3
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 10 Cheepjeep85 is on a distinguished road
Check the docs section at the top of the page there is a fsm in there with instructions. I can't link it for you but its there. You basically set the #1 cyl on tdc then line the dots up on the sprockets, the cam at the 6 o'clock pos and the crank at the 12 o'clock pos, there is a diagram in there that shows you how to count chain links to verify you have it right but I can't remember the procedure right off the top of my head.
Droooiiddd 2
Default
Old 11-07-2011, 06:26 PM   #4
Cheepjeep85
Wait a min I'm thinkin of a sbc, you line the timing marks up a little differently on a 258 the cam isn't directly over the crank, its more like 5 o'clock for the cam, and 11 o'clock for the crank. They have to line up so if you were to draw a line from the center of the cam to the center of the crank snout, your two timing dots on the sprockets would fall on that line.
Droooiiddd 2
Old 11-07-2011, 06:30 PM   #5
Images: 219
From a line center to center, still 6 cam and 12 crank...
Old 11-07-2011, 06:39 PM   #6
phyrph0enix
I figured it out... The Cam and Crank sprockets go on with the marks facing one another... like 5:00 Cam and 10:00 Crank. Then you spin motor until the Cam sprocket is at the 1:00 position and count the timing chain link pins. There should be 15 between the Cam and Crank marks. The Crank mark should then be at 3:00.
HOWEVER!!! When installing my H-Balancer... the OEM Tools Harmonic Balancer Installer tool broke off in my crank...................... . . . . . . . . . . . . . . . . . . . .
Has anyone had this happen? What did you do? I'm hoping I can find a way to back it out (easy outs) and salvage my crank... I'm not in the mood to rebuild an engine in a NE winter!!!
Thanks guys!
Vince
Old 11-08-2011, 01:52 AM   #7
jeepboy45 is offline
jeepboy45
Vehicle(s): 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
jeepboy45's Avatar
Rep Power: 7 jeepboy45 is on a distinguished road
Thanks guys!
Vince
If the tool broke off in the crank, is there really anything holding on the HB? If not, slide it back off and you can probably grab the remaining threaded portion thats left sticking out of the crank...I'm assuming that the threaded portion (hopefully) broke off long enough that when you remove the inch or more thickness of HB, there is actually enough sticking out...
But I'm sure you already thought of doing that.
I'm interested in hearing what you did. I mean AFTER you threw your undies in the washing machine... when you heard / saw it break off in the crank..
Talk about Murphys Law !! AARG!!
Good luck
Old 11-08-2011, 03:54 AM   #8
phyrph0enix
From what I could tell, the tool adapter broke off clean/flush with the nose of the crank... I'll look again tomorrow.
So, I had a couple of ideas:
1. Easy out........ Honestly, I'm not too optimistic about this option.
2. I was going to test the tool adapter and see if it will weld to a steel bolt. If it will, I was going to try and tac-weld a sturdy bolt to the centre of the threaded part (inside the crank). Then, I'd just have to back it out with the new bolt head. I think this is a more promising solution, but I'm concerned with the lack of space and the likelihood I'll end up welding the crank by mistake. I think a cooler arc and patience will go a long way with this method.
3. Raising holy hell with OEM Tools and see if they'll pay for a professional machinist to remove it - since their tool broke my car while I was using it for its intended purpose. Shouldn't the warranty cover everything that broke... Not just the tool?
Thanks guys!
Vince
Old 11-08-2011, 09:49 AM   #9
jeepboy45
jeepboy45's Avatar
Thanks guys!
Vince
I had thought of the welding solution too. But the thought of getting a stick or wire down in the hole, and NOT catching a thread or two....well, it can prob be done, but be careful.
Good luck with the tool company. I bet they'll replace the tool..AT THE VERY MOST. I'd say virtually no chance of them fixing your problem.
I bet you could drill a SMALL hole into the remaining tool stem get it out that way.
chain , r or r , timing
Double roller timing chain. Tony Marc Drivetrain 1 10-31-2012 08:04 AM
Timing Chain polish85 Drivetrain 5 11-04-2011 09:56 AM
dauntless 225 timing chain? josh84diffenbach Drivetrain 1 07-28-2011 12:42 AM
timing chain kicknjeep Drivetrain 23 01-05-2011 03:32 PM
304 timing chain Dennis 762 Drivetrain 8 03-16-2010 06:43 AM
