Default Swapping a T18 for a T15?
Old 01-01-2009, 10:11 PM   #1
72 CJ5 Owner
Images: 212
Anyone ever swapped a T18 fro a T15?
I can get my hands on a pretty good working T18 and since my T15 is shot... I'm thinking about throwing it in my CJ instead of rebuilding the T15.
Novak Jeep Conversions - Home has about every thing I would need to put the spicer 20 on, probably just need to do a little drive shaft work - might even get lucky and not need to do anything...
Just looking for people who have some feed back or experience with this swap...
Default Re: Swapping a T18 for a T15?
Old 01-03-2009, 11:02 AM   #2
coldwater is offline
coldwater
Moderator & Moral Officer
Vehicle(s): 04 Grand, Dodge 2500 CTD, 78 CJ7
coldwater's Avatar
Rep Power: 3 coldwater is on a distinguished road
I don't know. But I ASSUME the bolt pattern will be the same, but CHECK IT FIRST.Here is what I do know. It is about 2" longer than your T15 3 spd. It had a CRAZY number of diferent input shafts used not only by Jeep, but also by IH and Ford as well. It is a heavy sucker at 150 lbs alone. It's considdered to be one of (some say THE) strongest 4 cog trannies ever used in a Jeep. Since there is a crossover in the years from your T15 and the T18, I'll go out on a limb and say it would adapt for you. but I'm not that bright and have been known to be wrong. It and has been confused with the older T89, which is pretty much the same trans. I "THINK" the only diference is the main shaft support between the 2. If you can grab it at a good price, i would own it wether it fit or not, so lond as the case isn't cracked!
Old 01-03-2009, 12:12 PM   #3
72 CJ5 Owner
Images: 212
I picked it up yesterday evening. Novak has the correct input shaft for me and I need a new bellhousing. I'm not in the mood to scrounge around in my little home towns non existing junk yards so I'm ordering a new one from Krage MotorSports - Part Detail Page
I'm gonna tear it apart and clean it up... It is about 2" longer as you said and the transfercase spacer is another 2". That is going to shorten my rear drive shaft by 4"! I have a CJ5 so the shaft is already short as hell... I'll most likely cut and reweld my rear perches as the CJ has a 4" racncho spring lift already (with spring angle plates).
I'll keep ya updated.
Old 01-03-2009, 12:34 PM   #4
coldwater
coldwater's Avatar
Youch That's a lotta lift to lose 4"!! Matching angles is gonna be tough, You may end up having to add CV's.
Old 01-03-2009, 12:39 PM   #5
72 CJ5 Owner
Images: 212
LOL - Tell me about it! On a 7 it would be nothing but on a 5 it's a whole lot!
I'm hoping I can get away with it. Maybe not.
I'm even thinking of doing allot more then just a trans swap... Maybe for a new years project go through the whole CJ and fix all the crap I have rigged over time.
Old 01-03-2009, 03:29 PM   #6
coldwater
coldwater's Avatar
Let the good times roll! $$$$$$$$$$$$$$$$$ Even on my 7 I wouldn't go over 2.5" on the springs, and about 1" on the body. the DL angles are nearly perfect, and the drag link is juuuuuust about flat. No bump steer, no wonder, no dreaded DW. it clears the tires with plenty to spare (32's) my ground ctearance is better than I need, and it drives like a slotcar on the highway No more big (ish) lifts for me unless It's going to live on the trailer and or the outback! I wish you luck! Keep up the posts on your wins/ losses.
Old 01-03-2009, 06:21 PM   #7
72 CJ5 Owner
Images: 212
I've pretty much decided to just tear this thing apart... Well after today at least! I was playing around (put the tranny back in over the Holiday shut down) and F'in forgot to set my rev limiter... I was in some mud and over reved it and floated a valve keeper out and did some damage to the retainer (see pic). Doesn't look like it messed with the valve though (whew! they're high $$ stainless tulip ones)...
As for driving, it's just a toy, AKA a place to spend money... Drivability it is NOT designed for...
Old 01-03-2009, 08:09 PM   #8
jeep cj7 304 is offline
jeep cj7 304
jeep cj7 304's Avatar
Images: 9
Rep Power: 2 jeep cj7 304 is on a distinguished road
I've gone way past your limit with about 6 inches of total lift on 36's, still rolling stock axles. when it gets windy i go up to sixty and i can feel everything, but I'd never be able to do half the stuff i do with that little of lift and tires. Oh did i mention it's a daily driver.
Old 01-03-2009, 08:56 PM   #9
mylittlecj5 is offline
mylittlecj5
Vehicle(s): '74 CJ-5, 360 AMC Engine. Accel HEI module/ TFI Ignition. Holley Truck Avenger carb. T-150 3 speed trans. Model 30 Front diff. Drum Brakes. Dana 44 rear diff (Lincoln Locked). 4" SkyJacker SoftRide lift. 2" lift shackles. Front shackle reversal. TJ fender conversion in rear. 35x12.50x15 TSL Super Swamper tires. Optima Red-Top Battery. Full Roll Cage w/ 4 point harnesses. Custom Seating. 8000 Lb. winch on custom front bumper.
mylittlecj5's Avatar
Images: 9
Rep Power: 3 mylittlecj5 is on a distinguished road
^^^yea that...mine has 6" lift with 35" swampers. I'd DD it if it would stay running long enough!
With the (stock) 3:73 gears, it will comfortably cruise the hiway at 80 mph. Of course it doesn't crawl the rocks that well (YET)
Old 01-03-2009, 10:10 PM   #10
coldwater
coldwater's Avatar
you guys are better men than me. I aint no expert by a LONG shot, but after 30 years of various Jeeps in a few configurations, i do know that you would'nt catch my old rump haulin down the highway at 80 mph in a 6" lifted CJ5 sittin on 35's! I have used them as trail rigs, and as limited toolin around toys, but not DD's built like that. I had a buddy when I lived in NC that used to run a nearly stock CJ5 with 3" of lift, a little Buick V6, and a T18, that would follow the monsters through just about any course they could offer up. Pure elegance, just a master behind the wheel. I learned alot about how Jeeps work from him, and started using less to get more. My 7 has had the same U joints in her for 10 years now, and the only carnage i have suffered in a looooong time was a twieked tie rod. My fault for picking the wrong line.
swapping, t15, t18
