Is this the right carb for a '86??This is a discussion on Is this the right carb for a '86?? within the Drivetrain forums, part of the CJ Forums category; This is what the PO mounted on the Jeep. I think it's a Weber of some variety. Is this even ...
04-11-2010, 04:06 PM
Vehicle(s): 1986 Jeep CJ
Mostly stock, 258 c.i.d., T-176 tranny, Dana 30 front, AMC 20 rear, Dana 300 t-case, 31x10.50 tires, 2 inch body lift
This is what the PO mounted on the Jeep. I think it's a Weber of some variety. Is this even right for a '86?
Assuming this carb is OK, what is the shady-tree, idiot-proof, feed-it-to-me-like-strained-carrots method to adjust it so its running right??
Re: Is this the right carb for a '86??
04-11-2010, 09:09 PM
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 30 LS Dana 44 locker 3:73's,4"lift ,1" body.York OBA,
Warn 8274,Fullcage.
That's not a Weber that's the stock piece of Junk they come with.
04-11-2010, 09:14 PM
thats a carter bbd yes it is the correct carb for the jeep, yes its a pos, not much you can do if its already running badly, you can do the nutter bypass and make it run better in all sorts of ways. just google nutter bypass, if its something your interested in doing we can help you with it, if you live somewhere they do emission testing then don't even bother trying the nutter bypass
"OK so I am sick and crazy because I feel closer to a machine than to 99.999% of the members of my species, I can live with that.  " IOPort51
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Carb Kit
CoreyYoungCj577 |
Drivetrain |
5 |
12-01-2009 11:33 PM |
Which carb is the best?
CoreyYoungCj577 |
Misc CJ Discussion |
14 |
11-26-2009 07:16 PM |
Which carb is this???
Rust Bucket |
Drivetrain |
23 |
10-06-2009 10:44 PM |
which carb?
liljeeplover |
Drivetrain |
1 |
10-04-2009 07:57 PM |
carb ?
1sickcj |
Drivetrain |
12 |
08-10-2009 08:57 PM |
