Default PCV valve on a 304 motor
Old 10-11-2010, 07:25 AM   #1
grunt is offline
grunt
Vehicle(s): 1979 CJ 304, 400 automatic
Rep Power: 9 grunt is on a distinguished road
I have a Edelbrock carb and performer intake manifold. Where do I put a PCV valve at? I know the valve covers have no area for a "push in" type like a chevy 350. Thanks.
Default Re: PCV valve on a 304 motor
Old 10-11-2010, 04:19 PM   #2
Unless I'm missing something the pcv valve goes in the valve cover and the hose will go to the vac. fitting on the bottom of the carb.
Old 10-11-2010, 06:59 PM   #3
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 11 Cheepjeep85 is on a distinguished road
they should have a hole in atleast one of em with a grommet for the pcv valve
Old 10-11-2010, 08:39 PM   #4
derf is offline
derf
Vehicle(s): 1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress 1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress 1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
derf's Avatar
Rep Power: 8 derf is on a distinguished road
Since my engine is out, I snapped a picture of the back where the PCV grommet and valve goes. Mine's a 401 but it's the same Edelbrock manifold for all the AMC V8 engines. Mine doesn't have EGR and yours might so that may look slightly different.
The big empty hole next to the water outlet back there is where the grommet goes. The PCV valve then just pushes in to the grommet hole.
Old 10-12-2010, 05:47 AM   #5
grunt is offline
grunt
Appreciate the replys. The valve covers have no hole for a PCV valve....
Old 10-12-2010, 05:51 AM   #6
grunt is offline
grunt
OK, so the PCV valve goes in the manifold intake in the rear. Thanks derf...
Old 10-15-2010, 01:12 PM   #7
ThisGuyUKnow is offline
ThisGuyUKnow
Vehicle(s): 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG Honda vtx1800c
ThisGuyUKnow's Avatar
Rep Power: 10 ThisGuyUKnow is on a distinguished road
Hey derf up and to the left there is a tower thing coming out of the manifold. In the pic there are some washers sitting next to it.
What the heck is that I was looking at my Holly street dominator that i plan to use with my Tuned Port Injection swap and I could figure out what that is for??????
1986 CJ7 Laredo- 4.0,NV3550,D300,AMC20 3.31
2002 Honda VTX 1800C, 2006 F150 Supercrew 4x4
Old 10-15-2010, 01:19 PM   #8
Images: 219
The throttle cable bracket is mounted to the risers.
Old 10-15-2010, 02:01 PM   #9
derf is offline
derf
derf's Avatar
Like CJ said, that is a mounting boss for the throttle cable bracket. You can see the bracket bolted to the top of it. If you like I can take off the throttle bracket and bolt it on to the Holley Street Dominator manifold I have ready to go into my J10. That way you can see how it mounts.
Old 10-17-2010, 01:06 AM   #10
Saddle Tramp is offline
Saddle Tramp
Rep Power: 9 Saddle Tramp is on a distinguished road
Again, not sure where I came up with this but here is the AMC V8 diagram.
304 , motor , pcv , valve
Blower motor upgrade with in cab motor billyocup Chassis and Body 9 10-21-2012 09:38 PM
EGR Valve Rebuild? schhal Drivetrain 3 10-03-2012 07:46 PM
How are the wiper motor wires routed to the wiper motor? suburban99 Chassis and Body 8 04-07-2012 05:06 AM
PCV Valve willidj Drivetrain 4 01-18-2012 07:00 PM
proportioning valve blaylock6502 CJ Build Forum 2 04-03-2011 09:33 AM
