Default no spark
Old 06-11-2010, 02:32 PM   #1
54cj3b is offline
54cj3b
Vehicle(s): 1954 willys cj3b 1976 dj 5 rhd 1981 dj 5 rhd 1988 xj 1993 xj rhd 2006 kj
54cj3b's Avatar
Rep Power: 9 54cj3b is on a distinguished road
76 258 I6 everything was replaced with brand new parts ignition modular, ecm , coil , dist shaft , dist cap/rotor I had it running than it cut out, I get power to coil 12v but nothing from coil to dist not even while cranking went through the wiring with a fine tooth comb but cant find any faulty wires any ideas on what I may have missed checking I'm not the best with electrical ,
My first thought was the cps till I did research finding it didn't have one so that thought went out the window,
Default Re: no spark
Old 06-11-2010, 03:14 PM   #2
priceg is offline
priceg
Vehicle(s): 1982 CJ 7 4.2liter T176,D300,D30,AMC20 3inch lift, ARB lockers front and rear, 4.10gears, 33inch tires.
priceg's Avatar
Rep Power: 9 priceg is on a distinguished road
Take a spare spark plug and stick it in your coil wire to see if your coil crapped out. If you have power and ground at the coil, it my have retired.
Old 06-11-2010, 06:01 PM   #3
dave123 is offline
dave123
Vehicle(s): 1975 CJ5
dave123's Avatar
Images: 15
Rep Power: 9 dave123 is on a distinguished road
Your module could be bad as well. try swapping in the old parts one by one (assuming you still have them).
Make mine a V8 with no top.
Old 06-11-2010, 07:15 PM   #4
54cj3b is offline
54cj3b
54cj3b's Avatar
after some research today I think I may have found the problem it may be the pick up in the distributor guess I'll find out tomorrow fingers crossed
Old 06-11-2010, 11:23 PM   #5
Jeff in Norcal is offline
Jeff in Norcal
Vehicle(s): 84 CJ7, 258, T-176, AMC-20, D300, D30, 2.5" lift, Howell F.I., 32" MT's, ARB Rear Locker
Rep Power: 0 Jeff in Norcal is on a distinguished road
I agree with Dave. Check the module. I've had 2 go out in my older (80's) Chevy work trucks. Took one to Napa auto parts for the free electrical bench test to see if it was good. They checked it and said YES it was good. I spent hours going through everything else only to come back to the module. It WAS bad after all. They do crap out, so as Dave said, check that dude. Good possibility that's your problem.
Old 06-15-2010, 08:04 PM   #6
54cj3b is offline
54cj3b
54cj3b's Avatar
ran new wiring harness , new battery , new starter , solenoid , new coil , new dist shaft , new ecm , new alt , fuel pump , carb ,
checked for power at coil gets power but no spark ecm has power , pulled dist turned eng by hand to #1 set dist to #1 still nothing followed every step suggested and also every step in the big Chilton book this is on a 1976 dj5 258 need to get this thing going as its my wifes work vehicle theres no cps on this jeep
checked every thing in the book along with all suggestions everyone threw out this thing is becoming a royal pain in the ***
Old 06-16-2010, 08:46 PM   #7
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 11 Cheepjeep85 is on a distinguished road
PSSST...... HEI one wire keep it quiet don't tell nobody
Old 06-16-2010, 09:17 PM   #8
tvince is offline
tvince
Vehicle(s): 1978 CJ7
Images: 3
Rep Power: 9 tvince is on a distinguished road
I am in process of figuring out my ign issues as well do you have a full 12 v at plus side of coil my issue was the "Ballast Wire" breaking down / or up in resistance and after running a few mins the V at the coil would drop and start running rough below 10V and eventuaslly die at somewhere around 9.5V
Replaced 1.3 ohm wire with a .85 ohm "ballast resistor" and runs fine, But gonna start a new thread due to my inquiring mind regarding total resistance in the + coil line
I have 78 cj7 258 pointless dist and motocraft ign module
spark
No spark..... jagj52 Chassis and Body 8 06-29-2013 04:34 PM
No spark...!!! 007 Drivetrain 9 06-12-2012 05:17 PM
90 2.5 YJ no spark wondernad Jeeps other than CJ's 4 05-26-2012 07:38 PM
no spark!? red75cj5 Drivetrain 10 04-15-2012 01:50 AM
78 304 V8 - no spark gumbo Drivetrain 6 12-13-2011 09:55 PM
