Default Need suggestions on 1986 cj7 swapping to v8-350
Old 05-20-2011, 11:28 AM   #1
dvandebrake is offline
dvandebrake
Vehicle(s): 1995 Toyota T100 (awesome veh.) 1986 jeep cj7 with in-line 6 cyl. 258 5-speed manual trans.
Rep Power: 0 dvandebrake is on a distinguished road
Hi,
Am thinking of swapping out the old 258 in-line 6 to a chevy v8-350. Is there a lot of problems i'm going to be looking at? Also would like to know if my T-5 transmission, transfer case 300 and differenial can handle the extra power or do I have to upgrade to something stronger? I plan on re-wiring and having mounts added. If their are any good threads already posted would like so links to review.
Thank You,
Duane
Default Re: Need suggestions on 1986 cj7 swapping to v8-350
Old 05-20-2011, 01:19 PM   #2
gert is online now
Rep Power: 12 gert is on a distinguished road
Well they do spell these things Just Empty Every Pocket....and thats what your about to do seriously for a minute great swap it just requires money your tranny will die eventually and if you have the AMC20 rear it will strip out the 2 piece axle shafts...and your axle wind up will be worse with the added power. You will have to get a new V8 radiator,motor mounts tranny adapter and some re wiring of the ignition system re route the fuel lines Have you looked into the AMC V8 as an alternetive? it bolts to the tranny with no adapter you can get a brass rad and factory motor mounts for a lot cheaper than the Chevy V8
Old 05-20-2011, 01:48 PM   #3
Images: 219
One swap here ==>> http://www.jeep-cj.com/forums/f98/my...swap-cj7-1747/
http://www.jeep-cj.com/forums/f2/350...ve-train-7173/
http://www.jeep-cj.com/forums/f2/wra...350-swap-5275/
http://www.jeep-cj.com/forums/f2/t15...ine-swap-8361/
The Following User Says Thank You to CJ For This Useful Post:
dvandebrake (05-23-2011)
Old 05-20-2011, 02:08 PM   #4
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 9 JR74CJ5 is on a distinguished road
I was thinking of doing this, and swapping the whole drivetrain... Here was that thread, some good info from members for me, and maybe you...
http://www.jeep-cj.com/forums/f2/drivetrain-swap-8773/
Here was a little site info I found while searching for info for it...
1979 Jeep CJ-5 Buildup: AMC to Chevy 350 Conversion
and by doing a quick Google search, I found a lot of info, threads etc... (About 22,200 results) although as we know more than half of those will be crap not usable / worth nothing for info...
swapping a sb 350 into a 86 CJ7 - Google Search
~ JR
JR - ECV3
My Build< Click me
The Following User Says Thank You to JR74CJ5 For This Useful Post:
Old 05-21-2011, 03:49 PM   #5
RangerRick is offline
RangerRick
Vehicle(s): 85 CJ-7, Cummins 4BT Diesel, ZF S 5-42 5 Speed, Rear axle Ford Sterling 8.8 discs & Detroit Locker 4.10's, Front GM camper special D44 Flat top X-over hi-steer ARB, 4.10's, AGR super box, LoMax D300 4:1 gearing (94:1 ratio 1st-Low-Low). CV drive shaft, Goodyear MT/R Kevlars, 15x8 street locks, SOA front/SUA Rear hybrid 5.5" lift, Ham & CB 2-way radio, 09' JKUR on 37's and way too much to list.......
RangerRick's Avatar
Rep Power: 0 RangerRick is on a distinguished road
Duane,
I swapped a 350 in my CJ-7 using M.O.R.E. Bomb-proof motor mounts and a bellhousing from the Iron Duke I4 factory installed in CJ's from the early '80's. Depending on your driving habits, the T-5 may or may not work out for you. If the Jeep is somewhat stock and you don't run heavy trails like Duran or Odessa up in Calico with huge tires, the T-5 might last. If you've got 35's and like to wheel hard, you're going to want a heavier tranny. I could go into details but then this post would be very long. I like my CJ with the Vortec V8 and I recommend make sure you have fuel injection for the smog nazzis and driveability both on & off-road.
RangerRick
Old 05-21-2011, 07:08 PM   #6
Busted Knuckles is offline
Busted Knuckles
Vehicle(s): 86' Cj7
Rep Power: 7 Busted Knuckles is on a distinguished road
Simplicity, affordablilty, driveablility, reliablility, serviceablility, hands down, a late 80s to ealy 1990s 350 TBI (Vin K preferably, not a Vin 7), not to be mistaken with CPI (vortec motor). If you have a need for speed, then youd want to get PFI motor, like and LT1 or and LSx. Your expenditures will also sky rocket with a Port Fuel Injected motor, compared to the TBI set up.
You can buy bolt in motor mounts, in frame swap headers, swap radiator, and adapters for any trans/transfercase you can dream up.
Your T5 will take it, if you keep almost stock size tires and dont beat on it (no burn outs, or tug of wars with other 4x4s and such) Dana 300 wont know any different, and your 86 is supposed to have a D44 rear axle, so you good to go. If you are close to broke and have no money, go with the T5, otherwise, if your going through all this BS, change it out for a NV4500 from a chevy pickup, get one with a granny first gear. That will be one less adapter you need, and you cant screw up that trans if you try.
You would want a donor vehicle to grab everything out of, like a wrecked pickup. Thats the cheap and easy way. I just bought a 95 G20 Van with a great running TBI 350 for $160. It has rusty brake lines, and the owner didnt want to fix it. So theres the motor, trans, wiring harness, ECM all accessories, for less than it costs to fuel up my Suburban !
The Following User Says Thank You to Busted Knuckles For This Useful Post:
Old 05-23-2011, 11:53 PM   #7
dvandebrake
Hi all,
Thank you for all the good info. Looks pretty involved putting in a v-8. What about just getting a re-manutactured 258, maybe with the 4.0L head upgrade? Is there any re-build shops in So/Cal area that would have a motor like that?
Thanks All,
Duane
Old 05-24-2011, 03:46 AM   #8
JCsCJ is offline
JCsCJ
Vehicle(s): '86 CJ7 Laredo '08 Ford F250 '08 Ducati 848
JCsCJ's Avatar
Images: 20
Rep Power: 7 JCsCJ is on a distinguished road
Not all 86's have D44. Some came with the AMC20 that you will want to do a few upgrades to or swap to a D44.
Old 05-24-2011, 11:27 AM   #9
JR74CJ5 is offline
JR74CJ5
JR74CJ5's Avatar
Images: 80
Originally Posted by dvandebrake View Post
Hi all,
You can put a easier V-8 in... Although, yes you still may have a lot of little things to do...
Not too sure about that, but i do know there were a few good threads on this site alone on doing the upgrade... They're pretty detailed...
~ JR
JR - ECV3
My Build< Click me
Old 06-18-2011, 11:04 PM   #10
loud1983 is offline
loud1983
Vehicle(s): 1983 CJ7.
Rep Power: 0 loud1983 is on a distinguished road
i have that exact swap in my 83, it is a very difficult swap. the dana will hold up that transfer case is nearly bulletproof. but it is a money pit. huge pit. so if you really do want to do the swap get ready to throw money at it especially if you have no idea what you are doing
1986 , cj7 , suggestions , swapping
Swapping in a 4.0 jeepn4evr Drivetrain 3 10-14-2012 04:28 PM
swapping out springs thistle3585 Suspension and Steering 6 05-19-2012 12:22 PM
engine swapping help toby78 Drivetrain 8 02-10-2012 08:06 PM
swapping amc 20's slappy Drivetrain 12 02-04-2011 01:30 AM
Swapping a T18 for a T15? CJ Drivetrain 49 02-08-2010 04:58 PM
