Default Narrow verses wide track
Old 11-21-2011, 10:04 PM   1 links from elsewhere to this Post. Click to view. #1
driver007 is offline
driver007
Vehicle(s): 1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
driver007's Avatar
Rep Power: 2 driver007 is on a distinguished road
Could someone tell me how to tell the difference between narrow track and wide track? I have a chance at a narrow track 44 rear end and I would like to double check to make sure before I purchase. How or what would you measure? Thanks for any info!
Default Re: Narrow verses wide track
Old 11-21-2011, 10:59 PM   #2
jamie is offline
jamie
Vehicle(s): 76 cj 5 360, 999 tranny and dana 300 transfer case, dana 44 rear and dana 30 front diff
jamie's Avatar
Rep Power: 3 jamie is on a distinguished road
narrow track is 4 inches narrower than the wide track. you should have the narrow track under your jeep, unless a po swapped it out
evil will always triumph over good because good is dumb.
dark helmet
Old 11-21-2011, 11:12 PM   #3
hutchman is offline
hutchman
Vehicle(s): 1986 CJ7 - 90,000 original unmolested and rust free miles - Stock - well almost.........
Rep Power: 0 hutchman is on a distinguished road
These measurements are copied from Jeep Kings..........
Model/Version Spring Pads Wheel to Wheel Years
Dana 30/CJ Narrow Track 28" 53" '72-'81
Dana 30/CJ Wide Track 28" 56" '82-'86
Dana 30/XJ NA 60 3/4" '84-
Dana 30/MJ NA NA '86-'92
Dana 30/YJ 31" 60" '87-'95
AMC20 is
Spring Pad -Spring pad is 36"
WMS-WMS for narrow track is 50.5
WMS-WMS for wide track is 54.5
Look here for more info...
http://jeep.off-road.com/jeep/articl....jsp?id=277032
The Following User Says Thank You to hutchman For This Useful Post:
BusaDave9 (11-22-2011)
Old 11-21-2011, 11:16 PM   #4
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 5 Sasquach is on a distinguished road
Umm...I think it's 4" on the rear axle and 3" on the front
As posted above.
1978 CJ5, 258 w/4.0 head, Mopar MPI,T-18, D-20, D-30 w/tru-trac LS, Rubicon 4.5", Warn full float model 20 w/Detroit locker, 32x11.5 KM2's on factory 15x8s, Warn M8000
Old 11-22-2011, 09:03 AM   #5
Images: 335
Rep Power: 10 BusaDave9 is on a distinguished road
that's a good link hutchman
Old 11-22-2011, 12:42 PM   #6
driver007
driver007's Avatar
Could you tell me what wms means? And if you mearsure wheel to wheel would it change with rim size?
Old 11-22-2011, 01:15 PM   #7
Images: 335
WMS is Wheel Mating Surface. The width of an axle is measured from Wheel Mating Surface to Wheel Mating Surface. It is independent of the wheel width.
Now the backspacing is separate. That's the distance from the inner edge of the wheel to the Wheel Mating Surface where the wheel bolts to the brake. If you use wheel spacers or wheels with less backspacing it's another way to get a wider stance.
Old 11-22-2011, 02:43 PM   #8
driver007
driver007's Avatar
Thanks BusaDave9 and others for the info I will check it out to night I think I have a narrow track but with my luck. Lets just say if you wanted to buy a good item you would wait tell I have bought one then go get it, For sure I would have the dud and you would be real happy with yours.
Old 11-22-2011, 03:38 PM   #9
Resident 'Old' Jeep Shaman
Images: 141
Rep Power: 6 BajaEdition is on a distinguished road
nothing wrong with a narrow track Jeep
If you ever saw an original Jeep MB you would wonder WTF
and that MB is what started Jeeps reputation. What we have now is bigger and better brought on by the public asking for it
but remember, In WWII GIs depended on that SWB Super Narrow Based Jeep for their LIVES. and when they got back to the states, they wanted the little scout car that did everything, the Jeep
I agree that wide track is better, but I still Wheel 2 Narrow Track Jeeps and go everywhere.
www.justgoodtrails.com
Old 11-26-2011, 12:59 AM   #10
Saddle Tramp is offline
Saddle Tramp
Rep Power: 4 Saddle Tramp is on a distinguished road
Jeep went to the wide track as a way to add stability to the CJ after Ralph Nader and his gang of goons drummed the CJ5 out of existence.
narrow, track, verses, wide
LinkBacks (?)
LinkBack to this Thread: http://www.jeep-cj.com/forums/f2/narrow-verses-wide-track-11709/
Posted By For Type Date
www.matanzasjeepclub.com • View topic - axle width on a cj7? This thread Refback 10-15-2012 08:05 PM
switching from narrow track to wide track need some advice jesseb Suspension and Steering 1 11-27-2012 09:03 PM
Wide Track versus Narrow Track versus ???? jeepn4evr Drivetrain 6 08-24-2012 02:28 PM
Dana 44 Narrow Track vs AMC 20 Wide Track gerth21 Drivetrain 22 07-08-2012 03:41 PM
Would you swap wide trac axles for narrow track? OEM1984CJ7 Drivetrain 6 06-18-2012 11:02 PM
Narrow track build up or wide track swap cummins2007 Drivetrain 4 10-16-2011 08:30 PM
