Default MSD distributor on AMC 304 V8 question
Old 01-28-2011, 12:41 AM   #1
suburban99 is offline
suburban99
Vehicle(s): 1980 CJ7 304 V8 2011 Silverado 4x4 2004.5 Dodge Cummins Diesel 1997 Porsche Boxster
suburban99's Avatar
Rep Power: 8 suburban99 is on a distinguished road
Hey all, recently bought a 304 V8 CJ7 project. Has a brand new MSD distributor PN 8519, but has a motorcraft 12a199 spark module. The Jeep has not run with the new distributor as it is appears to be new (PO bought in 2009 gave me receipts) front cover was off, and I have re-installed most of the components, but how should I wire the distributor. Has a MSD coil as well. Do I need to buy the MSD series 6 control or can I use the 12a199 for now. I do not know if the motor has a knock or whatever so I want to get it started for cheap...
Default Re: MSD distributor on AMC 304 V8 question
Old 01-28-2011, 08:00 AM   #2
fzsk4p is offline
fzsk4p
Vehicle(s): Ground up YJ. Looking to get a CJ
Rep Power: 8 fzsk4p is on a distinguished road
Go to MSD.com and download the manual for the distributor you have.
Old 01-28-2011, 09:48 AM   #3
Bulto is offline
Bulto
Vehicle(s): '79 CJ5, V8 360 AMC: 190 rwhp @ 4800RPM's with 33' tires, T176, D300 twin sticked, D30 with Aussie Locker, AMC20, 3.54 r&p
Bulto's Avatar
Images: 6
Rep Power: 0 Bulto is on a distinguished road
Hi
For now you can run with the motocraft module.
I run my AMC 360 with the MSD 8915, blaster coil 2 with the Motocraft module, when the MSD repairs my MSD 6al series. It' work great.
See the diagram that I prepared for this connection. The Jeep OEM module & motorcraft Module wiring it's the same. Light Blue in the Jeep OEM Module & the white in the motocraft module it the same wire, so connect it to a Ignition Switch (hot in Start & run). If you have a tach, connect the signal cable to the negative wire in the coil.
Old 01-28-2011, 08:41 PM   #4
suburban99
suburban99's Avatar
Thanks for the diagram, hooked up as per your diagram and do not have spark.. suspect the module is hooped...how do you test the module?
Old 01-31-2011, 04:27 PM   #5
Bulto is offline
Bulto
Bulto's Avatar
Images: 6
You can test the module in advance auto or pep boys or auto zone stores
304 , amc , distributor , msd , question
distributor gasket question neal90 Drivetrain 2 04-26-2013 08:38 PM
distributor question panamacj5 Any and ALL Aftermarket Parts and Additions 2 03-28-2012 05:47 PM
HEI Distributor question? bdunnam Chassis and Body 5 02-03-2012 02:17 PM
258 Distributor question. CJ7 Shadow Drivetrain 7 01-08-2012 01:55 PM
Distributor Question ozark nate Drivetrain 4 06-08-2011 07:02 PM
