Default Jeepster
Old 08-04-2012, 05:01 PM   #1
jeepman is offline
jeepman
Vehicle(s): 1967 jeepster commando half cab 3speed 4x4 225 v6 dauntless
Rep Power: 0 jeepman is on a distinguished road
Hi
first a thank you for all the help that has been given.and now a please for more help.
I have a 1967 jeepster 1/2 cab v6 odd fire and i need some help indendifying my rear end.the tags are gone from the case but these numbers are cast in it.
The number 30 is on the left side
314 is center front
c-32908 is on the drivers side.the first number may be a 8 or 3
on the inside
12 4 79 dana d 33220 a3d99 41-11
thank you for any insight on this problem
have a great day robin
Default Re: Jeepster
Old 08-04-2012, 05:09 PM   #2
tarry99 is offline
tarry99
Rep Power: 9 tarry99 is on a distinguished road
Originally Posted by jeepman View Post
Hi
314 is center front
on the inside
Jeepman
Its all about the bolt pattern.........Go online and Google Jeep Dana axle ID, look at the pictures and match yours up. Of course if your looking for gear ratios you'll have to drain the oil and count teeth.
Old 08-04-2012, 05:29 PM   #3
Rep Power: 16 Old Dog is on a distinguished road
Hi
314 is center front
on the inside
if the 30 is cast into the centersection it's a dana 30, the cover would look like this
The 12 4 79 should be date it was made.
the 41-11 would mean 3.72 gears
I tried running the BOM # but go noth'n. most of the time there shoul be 6 numbers not 5.
not sure on the a3d99 where did you find that at, on the tube or centersection?
Old 08-04-2012, 06:09 PM   #4
Check out this thread:
http://www.jeep-cj.com/forums/f105/cj-axles-12186/
It's geared toward axles for CJs but I bet yours in among them.
I wouldn't' be surprised if it was a Dana 44 like this:
Old 08-04-2012, 06:11 PM   #5
That's not a factory top is it? I don't think the factory ever offered it as a half cab.
I'd like to see it. Could you post some pictures?
Old 08-04-2012, 08:51 PM   #6
Incommando is offline
Incommando
Incommando's Avatar
Rep Power: 7 Incommando is on a distinguished road
There were factory Commando half cabs. They came open top, full metal top, half metal top, and also a true convertible that was pretty fancy for a jeep. The full metal top was the most common..
OP: Your rear axle is a Dana 30. Dana 30's were rarely used as rear axles but the Jeepster Commando ( C101) was one application that had them. 41-11 gears = 3.73's, a very common gear ratio.
You need to go register here: http://jeepstercommandoclub.com
They are far and away they best resource for Commando ( Either 66-71 Jeepster (C101) or 72/73 Jeep (C104) ) info and parts. Great group of folks.
jeepster
1970 Jeepster priceg Great Deals! 0 04-05-2013 09:31 PM
Jeepster Commando Niedhogg Jeeps other than CJ's 14 03-05-2012 07:02 PM
Jeepster Resurrection Im Not Spam Jeep News and RSS feeds. 1 06-27-2009 01:56 AM
68 jeepster donnie12b Jeeps other than CJ's 1 06-02-2009 06:46 AM
Jeepster & AMC Pacer CJ Jeep News and RSS feeds. 3 01-21-2009 08:26 PM
