Default J20 axles
Old 04-10-2011, 09:16 AM   #1
Out of my mind CJ5 is offline
Out of my mind CJ5
Vehicle(s): 74 CJ5 scrap built CJ7
Rep Power: 9 Out of my mind CJ5 is on a distinguished road
Alright i just picked up a set of axles from a j20 that measure 66'' backing plate to backing plate for $250. the rear is a dana 60 frint dana 44 and its 8 lug. anybody used these before for full width conversion? was this a good buy? they have 3.73 gears and a locker, they will be going on a cj7 with SOA and 4'' springs and 1'' drop shackles so i needed more width
Default Re: J20 axles
Old 04-11-2011, 08:40 AM   #2
SOA will give you about 6 inches of lift. All in all you're going to have a 10 inch lift. What tire size will you be running? If you get oversized tires you will want to get rid of the 3.73 gears.
IMHO I would keep it much lower. Wide is good but you'd be 10 inches wider than stock.
If you really want those full width axles check out this link:
CJ Full Width Axle Swap Kit - Poison Spyder Customs
Out of my mind CJ5 (04-11-2011)
Old 04-11-2011, 11:11 PM   #3
Out of my mind CJ5
thanks that helps, i have 37's for it. How hard would it be to weld on an outboard, i can weld sheet metal decent but have never done anything that important
Old 04-11-2011, 11:38 PM   #4
fzsk4p is offline
fzsk4p
Vehicle(s): Ground up YJ. Looking to get a CJ
Rep Power: 8 fzsk4p is on a distinguished road
You can start here
Dana/Spicer Bill Of Material Numbers
This will help you ID just what you have. Dana 44`s and 60`s came in many flavors. The BOM will tell you plenty
Dana Holding Corporation - The Expert Axle Bill of Material
The Expert - Information for driveshafts, u-joints, brakes, axles, heavy axles, light axles
The Dana 44 front axle bible
Mr.N's Dana Articles to Include 44, 60 informaiton.
Mr.N's Dana Articles to Include 44, 60 information.
This might help
Pics of outboarding springs
Google "out boarding CJ springs" and you will get LOT`s of information.
For parts. Highly recommend Dan at RuffStuff. His parts and customer service is simply great.
Frame Outriggers 4.5" [0692200] - $57.00
The Following User Says Thank You to fzsk4p For This Useful Post:
Out of my mind CJ5 (04-12-2011)
Old 04-12-2011, 12:01 AM   #5
Out of my mind CJ5
wow youre good ive been searching cj7 outboard springs for almost two days and got nothing, thanks for all the links man i appreciate it
Old 04-12-2011, 12:06 AM   #6
Out of my mind CJ5
another question is what would be the best way to mount shocks and what kind should i get?
Old 04-12-2011, 07:37 PM   #7
I could be wrong but wasn't the j20 set up for sua?
You might have been better off using a chevy front 44
as it was set up for soa.
axles , j20
full size axles vs. widetrack axles cj7pimp Drivetrain 12 05-16-2013 02:10 PM
new axles cj7mudder24 Drivetrain 15 01-28-2012 03:33 AM
uni-mog axles IOPort51 Great Deals! 3 01-27-2012 01:27 AM
What axles? Allen9878 Suspension and Steering 3 04-27-2011 06:57 PM
what axles do i have ? cjnewbie Drivetrain 23 04-18-2010 03:38 PM
