Default Identify Axle/Transmission/transfer Case?
Old 08-02-2010, 04:09 PM   #1
TravisNC is offline
TravisNC
Vehicle(s): 1982 CJ5
TravisNC's Avatar
Rep Power: 0 TravisNC is on a distinguished road
I have an 82 CJ 5, just picked it up from a guy and want to know how to identify the axles, transmission and tansfer case...
Is there markings and if so where are they located.
I'm doing a once over on it and just want to be able to identify everything.
Default Re: Identify Axle/Transmission/transfer Case?
Old 08-02-2010, 04:23 PM   #2
CJKrawler is offline
CJKrawler
Vehicle(s): 1984 CJ 7 2005 Liberty CRD
CJKrawler's Avatar
Images: 8
Rep Power: 8 CJKrawler is on a distinguished road
the trans and xfer case will have numbers on them, also a name on them. Once you get that info, you can do a search. The axles, just get a picture, or at least know what they look like, and check out something like this Axle Identification Chart that should get you started.
The Following User Says Thank You to CJKrawler For This Useful Post:
Ctknorr (05-24-2017)
Old 08-02-2010, 08:26 PM   #3
Resident 'Old' Jeep Shaman
Images: 141
when you get the numbers off the tranny and t case, go to novak adapters website and look under the knowledge section where they can help you identify those units
Old 08-03-2010, 09:28 AM   #4
My guess is that you have a Dana 30 front axle, AMC 20 rear, a T5 tranny and a Dana 300 TCase. But to make sure a previous owner didn't swap anything out follow the advice of CJKrawler and BajaEdition to make sure.
Old 08-03-2010, 10:39 PM   #5
LASTCJ786 is offline
LASTCJ786
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
Rep Power: 8 LASTCJ786 is on a distinguished road
But if you have a4speed it could be aT176 or T4,Dana 300.
Note a T176 is a long shifter.
The last CJ7 86
case , identify
Transmission oil over fills the transfer case??? Sjcwaterboy Drivetrain 4 03-15-2013 10:47 AM
transmission & transfer case JR72450 Drivetrain 11 03-08-2013 10:34 PM
what Transmission & Transfer case Shvy Drivetrain 6 10-12-2012 01:40 AM
Transmission and transfer case swap diffosjeep Drivetrain 4 08-21-2011 02:56 PM
Need help w/ transmission/transfer case mount cdlongjr Drivetrain 4 07-16-2010 03:38 PM
