Default Hard to start
Old 05-04-2011, 07:46 AM   #1
228jeeper is offline
228jeeper
Vehicle(s): 86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
Rep Power: 9 228jeeper is on a distinguished road
Jeep is hard to start after sitting for a couple of days, sometimes overnight. Once it does start and warm up, I can leave it sit for up to say half a day and it starts fine. Wires and connections to ballast resistor seem loose to me. I have recently replaced the pos and neg battery cables and the battery is good. I know this problem might be vague, but any idea where I would start? I wouldnt think it should be this hard to start when cold. Thanks.
Default Re: Hard to start
Old 05-04-2011, 08:04 AM   #2
Does the engine crank? If so it must be either spark or fuel. Use a spark tester.
Pump the gas and see if gas squirts into the carb.
Old 05-04-2011, 08:06 AM   #3
DHugg is offline
DHugg
Vehicle(s): '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Images: 46
Rep Power: 9 DHugg is on a distinguished road
1980 CJ-7 with 304CID had the same trouble when I bought it in D'Iberville in Nov 2009. I re-oriented the two-outlet fuel filter just before the carb inlet so that the return feed was on top, replaced the rubber. But I believe the thing the did the trick was removing and capping the fuel return line to the canister.
All the rubber hoses were 'hosed', and I still have to go back to the rear to work over the fuel tank, but she will sit for a couple weeks without me having to crank forever to get fuel to the carb.
Old 05-04-2011, 08:08 AM   #4
228jeeper
Yes, the engine cranks, and it will even start after a while when cold. Once it is hot, starts with no problem. Runs fine after starting too.
Old 05-04-2011, 08:37 AM   #5
228jeeper
It seems the charcoal cannister has been removed and there is a hose that is positioned as if would have connected to it somehow. It is not capped, but open. Is this what should be capped? I will try to get a pic up a little later. Thanks.
Old 05-04-2011, 11:04 AM   #6
JeepinTX is offline
JeepinTX
Vehicle(s): 1983 Jeep CJ7 - 31K original Miles 4.2L 4-Speed, 2007 Screamin Eagle Harley Dyna, 1992 Suzuki Katana
Rep Power: 0 JeepinTX is on a distinguished road
I am also having the same problem. A little research pointed me to the Card as the issue. I have replaced all the ignition components as well as the battery so I know spark isn't the issue.
Check the carb and make sure its not time for a rebuild!
Old 05-04-2011, 12:13 PM   #7
gillmore is offline
gillmore
Vehicle(s): FORMER: 1979 Jeep CJ5 w/ stock 304 V8, T-150, Dana 20 transfer case, Dana 30 Front & AMC 20 rear, MC 2100 carb, 31x10.5x15 (8" wheels), no lift (HD leaf pack), Warn 8274 winch, ~99K miles.
gillmore's Avatar
Location: Northern California (Petaluma, Sonoma County)
Images: 43
Rep Power: 9 gillmore is on a distinguished road
I have the same problem and a couple of priming pumps in the morning before starting helps most of the time, so I'm living with it. I was told (if I remember right -- not my firsthand experience) that when it comes time to rebuild my carb, to check that the metal isn't pitted -- preventing new rubber parts (accelerator pump) from sealing properly.
Old 05-05-2011, 09:45 AM   #8
228jeeper
Here we go again. Jeep was hatd to start this morning but got it running. Took the air cleaner off and looked into the carb. It is getting gas. My cj has a manual chole installed by the previous owner. After looking at it awhile and feeling something just was not right, It seems that the choke cable is not even attached to the carb in any way, please see the pics. Could this be causing my problem? If so, how do I reconnect it and where. Thanks.
Default
Old 05-05-2011, 10:51 AM   #9
73jeep is offline
73jeep
Vehicle(s): 73 CJ5 TBI 258 t14 d20 - Rebuild in process 08 Duramax Crewcab 4x4
73jeep's Avatar
Rep Power: 0 73jeep is on a distinguished road
That disconnected choke cable is 100% you problem. The engine needs a richer fuel mixture during startup and when cold. It looks like you missing some pieces for the manual choke. Run down to the parts store and pick up another manual choke conversion kit, they only cost a couple of bucks. Installing it is pretty strait forward, it attaches to the side of the carb and manually operates the choke arm which is in the 2in round boss down low on the valve cover side of your carb.
Good luck!
Old 05-06-2011, 12:07 AM   #10
228jeeper
Are the manual choke conversion kits you are talking about carb specific? Because I have no idea what carb is on mine now. I rigged the choke cable somewhat, and wouldn't you know it she starts up cold like a charm, and runs better when warm. Thanks for your help.
hard , start
Hard cold start and backfiring during acceleration CaseyCJ5 Drivetrain 6 11-27-2012 03:50 PM
Hard to start when warm Shazam Drivetrain 7 10-05-2012 09:23 PM
rough idle, hard start 1984 CJ7 Drivetrain 3 04-15-2012 01:06 AM
Can I use a hard top and hard doors? doyle78 Chassis and Body 13 02-29-2012 03:31 PM
jeep hard start 304 contraj Chassis and Body 3 03-30-2011 10:17 AM
