Default Great 2100-2150 adapter plate
Old 03-27-2013, 05:52 AM   #1
Jimbos76cj is offline
Jimbos76cj
Vehicle(s): 83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!! Ask me about my head light upgrade harness!!!
Rep Power: 8 Jimbos76cj is on a distinguished road
If any one has done the swap already and used the mr.gasket adapter next time you rebuild the carb throw out the mr gasket and order one of these.
$45.00 shipped it came with the bolts, bottom gasket and gasket for the 2100 that seals off all the open holes on the bottom. This thing is solid and fits like a glove.
Here's what the mr.gasket 1937 looks like. See how it's not square in the back? That causes all kinds of hell with leaks.
His email is [email protected] you can email him directly or go through his eBay store. I don't have his contact info but if I find it again ill post it
The Following User Says Thank You to Jimbos76cj For This Useful Post:
JR74CJ5 (03-27-2013)
Default Re: Great 2100-2150 adapter plate
Old 03-27-2013, 10:45 AM   #2
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 10 JR74CJ5 is on a distinguished road
That's sweet!
~ Jr
JR - ECV3
My Build< Click me
Old 03-27-2013, 11:59 AM   #3
thiswontbetooexpensive is offline
Vehicle(s): 1980 CJ5, Stock and original 258I6, Dana 300, T 176 (poor thing needs a little bit of time and a few kind words)
thiswontbetooexpensive's Avatar
Images: 74
Rep Power: 7 thiswontbetooexpensive is on a distinguished road
The contact information would be great! I will hopefully be needing one of these in the next few months. I might have found a place for a MC2100 and it came with adapters for an additional charge.
This looks to be WAY more functional.
Thanks!
Old 03-27-2013, 12:52 PM   #4
Jimbos76cj
I used the email in the post.. That will give you a direct line to him. Ill be on eBay later tonite and ill see if i can dig up his contact info on there
thiswontbetooexpensive (03-27-2013)
Old 03-27-2013, 12:58 PM   #5
johnnyreb is offline
johnnyreb
Vehicle(s): 1980 cj5 258ci straight 6, 31x10.50's. Partial Teamrush iginition upgrade, MC 2150 Carb. 4.0 head swap, factory header. I call him "Eugene". Dad's jeep when he raced in the 70's. Cj2 running gear, ford 300 cu in 6 cyl with 3 deuces. Fiberglass model T body and hand laid fiberglass hood. welded 5.38 gears and beer keg fuel tank. see avatar Wife's: Black 04' Liberty with all the bells and whistles.
johnnyreb's Avatar
Images: 17
Rep Power: 6 johnnyreb is on a distinguished road
I think i've seen his ebay page, he sell carbs too. I have the mr.gasket, but made a pattern with plans to machine out a new out of billet aluminum. I was gonna make mine square with no cut outs on the sides.
I call him "Eugene"
Old 03-27-2013, 03:28 PM   #6
Jimbos76cj
The front cut out is needed for that low hanging cover that goes over the power valve. I think the side with the throttle hook up needs to be cut out also for clearance.
Old 03-27-2013, 07:18 PM   #7
johnnyreb
johnnyreb's Avatar
Images: 17
i'll look later when I go down to the shop. I have a 2100 on the bench right now, parts came today and I finish it tonight. any idea how thick his adapters are?
I call him "Eugene"
Old 03-27-2013, 07:34 PM   #8
Jimbos76cj
IF I get a chance tomorrow i can check.. Id say at least 1/2". instead of FHSC screws he uses regular socket caps.. the hole head is below and there is still 1/8 or so of material below em.
Old 03-27-2013, 07:36 PM   #9
mtnwhlr is online now
Images: 56
Rep Power: 12 mtnwhlr is on a distinguished road
MotorCraft in eBay Motors | eBay
This thanks to Alpha6
Old 03-28-2013, 08:16 PM   #10
johnnyreb
johnnyreb's Avatar
Images: 17
I did a little investigating early today. I'm betting the plates are 3/4". I'm debating o\in attempting one using 1" to reduece chance of warpage even more. I also think I can reduce the front and side reliefs a bit too. I'll have to hunt a piece of 1" aluminum and do some lay out work.
I call him "Eugene"
The Following User Says Thank You to johnnyreb For This Useful Post:
Jimbos76cj (02-24-2014)
adapter , great , plate
the motorcraft 2100-2150 2-bbl carb. and related posts CJ BRIAN NJ Drivetrain 25 06-28-2013 09:31 AM
Dana 300 adapter plate driver007 Drivetrain 25 02-17-2012 05:18 PM
