Default front axle offset??
Old 08-20-2009, 06:58 PM   #1
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 12 mylittlecj5 is on a distinguished road
Has anyone noticed if their front axle is offset a little to one side or the other?
I was installing the new PS box on my CJ5, and while doing a rough alignment, I noticed my front left tire is offset about 2 inches to the left. The right one seems to line up directly with the rear tire.
Knowing AMC and Jeep's quality control, I'm thinking it might be normal production tolerances
I do have a Superlift SoftRide suspension lift, and a shackle reversal, but those measure out to be correct, so that is not the problem.
Default Re: front axle offset??
Old 08-20-2009, 07:14 PM   #2
LongHorn is offline
LongHorn
LongHorn's Avatar
Images: 39
Rep Power: 12 LongHorn is on a distinguished road
X2 on the Quality control, but I have not run into that particular issue myself.
Old 08-20-2009, 07:47 PM   #3
CJ is online now
Images: 219
Sounds like a normal old CJ to me... Your 74 is 35 years old... Many things have happened to the old girl over the years. I bet it was 1" out on either side when she was made...
Old 08-20-2009, 09:35 PM   #4
WOW how did you do that playing in the mud
Old 08-20-2009, 11:54 PM   #5
kicknjeep is offline
kicknjeep
Vehicle(s): 1999 TJ, 1976 CJ-5 2 seater
kicknjeep's Avatar
Images: 20
Rep Power: 9 kicknjeep is on a distinguished road
I'll have to check mine in the morn.
Old 08-21-2009, 08:08 AM   #6
mylittlecj5
Images: 9
I'm not sure when it happened. Everything seems to line up all right (springs, hangers, U-bolts, ect...) just the axle seems to be moved over a little.
On a related note, is there a difference in the WMS of a stock Dana 30 and dana 44 in the intermediate CJ axles? That could help explain some of the offset, since the right tires seems to line up ok.
Old 08-21-2009, 08:47 AM   #7
Not real sure about the 44, The WT 30 is about 1 1/2" wider than the WT 20. something like 54 1/2" and 56"
Old 08-24-2009, 11:32 AM   #8
kicknjeep
kicknjeep's Avatar
Images: 20
well the driver side axle "DOES" stick out right at 1" further than the passenger. Normal?
axle , front , offset
Swap front axle on 75 cj5 Firejunky Misc CJ Discussion 2 03-16-2012 09:00 PM
Looking for a little front axle help, please dpuck Drivetrain 22 05-09-2011 09:20 AM
Front Axle gotaluvaCJ Drivetrain 1 03-16-2011 09:54 PM
noisy front axle chilidawg72 Drivetrain 10 12-28-2009 10:06 PM
Offset T-case & Rear Centered Axle fredr1980 Drivetrain 0 09-05-2009 04:04 PM
