Default Electric fan
Old 07-04-2012, 11:32 AM   #1
drivert51 is offline
drivert51
Vehicle(s): 1972 CJ5, 304, 3 speed
drivert51's Avatar
Images: 18
Rep Power: 8 drivert51 is on a distinguished road
Thinking about putting an electric radiator fan on, to save a little room. Anyone know the pros/cons?
The Following User Says Thank You to drivert51 For This Useful Post:
poppatello (07-04-2012)
Default Re: Electric fan
Old 07-04-2012, 12:21 PM   #2
I am pro electric fan. they are quieter, require less power, operating temp sooner, not running if not needed.
cons: need a control circuit with thermostatic switch and high amp relay. We all know about how much fun electrical problems are with a CJ.
Old 07-04-2012, 02:31 PM   #3
Rep Power: 18 Old Dog is on a distinguished road
If you get one make sure it's at least 2600 cfm (more is better) to keep it cool.
I like the idea that I can turn it off at water crossings, I've seen fans go through rads. before.
I also have a manual switch so I can turn it on with the engine off to help cool it down.
Old 07-04-2012, 03:09 PM   #4
I am def pro electric this is the swap I am doing, I also want to put a control switch on the dash to control it
The CJ Build – Page 14 | In a Jeep
Old 07-04-2012, 05:48 PM   #5
Purple77CJ7 is offline
Purple77CJ7
Vehicle(s): 1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
Purple77CJ7's Avatar
Images: 37
Rep Power: 10 Purple77CJ7 is on a distinguished road
I was running a Flex-a-lite black magic electric fan that I think is 3000 to 3200 cfm. can't remember for sure, good fan and shroud. I'm currently back to stock fan with a small Flex-a-lite pusher fan (long story). Flex-a-lite I think makes good products.
Old 07-04-2012, 10:41 PM   #6
poppatello is offline
poppatello
Vehicle(s): 84 Cj, 4 Banger, 4.5 BDS Lift, 35" KM2, Twin Stick, Nuttered...
poppatello's Avatar
Rep Power: 0 poppatello is an unknown quantity at this point
This is another upgrade I plan to do when I install my 304. I thanked you for this thread...
Old 07-05-2012, 09:38 PM   #7
jasonmark1993 is offline
jasonmark1993
Vehicle(s): FJ cruiser (wifes ride) 2008 ZX10R, 73 CJ5, 408W, Toploader, Dana 20, 9" Dana 30 5.38 gears, next purchase=slicks
jasonmark1993's Avatar
Images: 10
Rep Power: 9 jasonmark1993 is on a distinguished road
I recommend spending a little more money up front and getting the flex a lite one with dual fans that bolts right to the factory rad mounting locations.
Then get a variable speed controller by flex a lite as well.
I've done a couple junk yard swaps and while they work, I got sick of always looking at how it just didn't fit right.
I drive around in 110* heat and haven't gone over 210;(190* when its only 95 out) should be less once I get rid of these stupid underdrive pullies. When I get home I can hold my hand on the radiator fins its so cool.
edit; best deal on the fans was summit, got the controller from summit racing.
73 CJ 5, 408 Windsor, Toploader, 9"
Old 07-07-2012, 10:27 PM   #8
paparooster is offline
paparooster
Vehicle(s): Rig: '74 CJ5 Motor: AMC 360 V8 Holley 670 Truck Avenger carb Trans: NP435 Transfer: Dana 300 Twin Stick Front axle: Dana 44 w/ Detroit Locker, Chromolly Axles, 4.88 Rear axle: High Pinion Dana 44, 4.88, Detroit Locker, Disc Brakes Suspension: Blazer Springs.Others:Warn Winch, Via-Air onboard air, Red Dot rear heater, H.E.I Distributor, Dual Electric Fans, Custom front & rear drive lines, Toyo Tires 15 x 35 x 13.5, Painless 70 amp fuse buss, 140 amp alternator 1978 cj7 304 turbo 400 Quadra-trac transfer
Rep Power: 8 paparooster is on a distinguished road
I have a Flex-a-lite dual fans made for a cj comes with control temp unit manual switch .. Dont have to worry about fan going into radiator or a hose while on the trail wheeling
Old 07-07-2012, 10:29 PM   #9
jasonmark1993
Images: 10
correction; best price on the fans were through amazon
Old 08-16-2012, 05:19 PM   #10
Turbogus is offline
Turbogus
Vehicle(s): '78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi '96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
Turbogus's Avatar
Rep Power: 8 Turbogus is on a distinguished road
as for me and 'Black Betty' we're going with roll your own as IF something goes haywire I'll know right where to look. That, and the expense of an 'all new' kit prohibits me from going that route.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
electric , fan
Electric Fan tonkatrucksryan Chassis and Body 10 02-20-2012 12:42 PM
Electric fan help poser Drivetrain 2 09-11-2011 10:32 PM
Electric Hubs for CJs GatorBate Drivetrain 16 02-02-2011 10:41 PM
Electric Fan HELP!!!! dave pam Jeeps other than CJ's 5 09-06-2010 10:44 PM
Electric Water Pump vs Electric Drive kit jeep cj7 304 Drivetrain 8 01-30-2009 10:03 PM
